3M RTE8000 HS not detecting passport when tried with scan
3M RTE8000 HS scanner with e-MRTD scanning
  • 383 Answers
SOURCE: Vista Driver for Canon N640P flatbed Scanner
Did u re- boot your computer after you installed the cd's?
Posted on Nov 27, 2007
BinaryCode
  • 54 Answers
SOURCE: scanner error
Try uninstalling and reinstalling the driver. If it occurs again, the the manufacturer of the scanner of yours may have some special thing (security) in the flatbed of the scanner. Like for example scanning money or so.
Posted on Jun 12, 2008
djfrankn
  • 100 Answers
SOURCE: scanner is not detecting images / photos to scan
The image sensor may have gone bad. Try reinstalling the driver, if it does not work... It is time to get a new one (it is more expensive fixing a scanner than buying it brand new). Sorry. Good luck.
Posted on Jan 03, 2010
  • 78 Answers
SOURCE: My scanner scans black Does not scan document.
Does the scanning light come on? The light may be burned out. Also Try cleaning the scanning tip.
Posted on Jul 17, 2010
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Posted on Sep 05, 2010
MFC-L27OODW Monoblack. How do I print double sided page from passport?
Scan the document to the computer then piece the two pages together on a page using whatever editing software you use. then print it again. I don't think there is any way to duplex copy something like a passport since it requires it being placed on the scanner and scanned in two copies.
Dec 29, 2015 | Brother MFC Office Equipment & Supplies
3m RTE8000 HS compatibility with windows 7 professional 64 bit machine
Hola amigo, si quieres encontrar un 100% genuina de la clave de activaci?n y activan, se enteran de este art?culo en mi blog y disfrutar de ella, visite: https://plus.google.com/108575569080700033613/posts/4D5pxfTcdu9 ahora, si quieres encontrar herramientas de esta activaci?n.
Jul 23, 2013 | Office Equipment & Supplies
Hi, my question is once i open the lid of my scanner where do i place the small passport foto that i want to scan? Thanking you in advance. Lina Galasso
There should be an rectangular outline on the glass, once you open your scanner. Place the passport in a corner. Close the lid, and scan.
If its the wrong way, just move the passport around, try it again.
Aug 07, 2011 | Computers & Internet
Auto detection can not be set as default
A 'Driver' is only the software portion to connect two hardwares. You need to install a printer driver for Printer, or a DVD driver for a DVD drive. Similarly, the scanner driver just connects the scanner to the computer.
You need to use a Scanning software to use the scanner. Canon offers CapturePerfect 3, using which you scan documents, do rotation, convert to PDF etc. CP3 has option to detect the page size. CP2 is available free of cost from Canon sites. CP3 comes with the scanner.
S. Mohan, Chennai, India
Apr 01, 2010 | Canon DR-5010C Scanner
Rejected passport pictures
The marks are probably a result of the chemical process that occurs to make the image appear on the Polaroid paper. While not visible to the naked eye, the process of scanning that the consulate is using is able to detect more than what is merely visible on the picture. This added detected "information" is showing up on the scan output, rendering it unusable.
You will probably not be able to submit an acceptable picture on any Polaroid instant film paper to the consulate for this reason. Most photography studios off instant passport pictures for about $10 - $20. AAA used to offer a deal of this, but it's been a long time since I needed a passport picture, but check with them first if you are a member. Just make sure you can get a picture that meets the technical requirements (size, color, etc.) of the consulate before having the picture(s) taken.
Sep 30, 2009 | Polaroid Digital MiniPortrait Digital...
Not scanning full page Canon DR-3080II/CapturePerfect
U should select 'Scanners maximum'  and try this. I have found this does not work midway, after some scans. So close and exit out of captureperfect, re-enter and try. This should work.
S. Mohan
Nov 19, 2008 | Canon DR-9080C Path-Through Scanner
Scanning Different Sized Sheets
There should be a preview option that scans more quickly than actually scanning the page. Then after the preview shows, you can select the area that you want to actually scan and then you hit the Scan button. If you are using the Canon software, this should work for ya.
Nov 07, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Scanner or PC?
Neither is it a prob with the computer nor with the scanner.
Let me guess,
either is your usb connection cable longer than 2m or you have connected the usb printer/scanner cable to a usb hub.
Do use a cable no longer than a max of 3m and do connect the usb cable directly to the computer usb slot.
Oct 18, 2007 | Brother DCP-110C All-In-One InkJet Printer
130 people viewed this question
k24674
jasbo
jasbo
