Affinity washer atf8000fs will not spin out
SOURCE: affinity washer not wanting to spin!
My Affinity washer quit spinning during the rinse cycle 14 months after we purchased the machine. We checked to make sure ithe drain was clear, and we tried changing the size of the loads. Nothing we tried worked. I was not getting any error codes on the control panel. We called a technician out to our house to see if it could be fixed. He diagnosed the problem as the control panel. We called Frigidaire to see if they would help us out with the cost of the repair since the machine was only 14 months old, even though our one year warranty had expired. They stated that they would not cover the replacement of the control panel. After the technician replaced the control panel and tried the machine, it still did not work. He called the Frigidaire tech support to find out why, and they told him that he needed to replace the door latch system, not the control panel. After he replaced the door latch the machine worked fine. When researching this problem online, I discovered that Frigidaire has had several problems with the door latch system on their front loading washing machines. They previously had a class action lawsuit due to this problem. When I found this out, I called Frigidaire to see if they would pay the repair bill we had incurred, even though our warranty had expired 2 months ago. After they contacted the technician that worked on our machine, Frigidaire decided that they would pay the cost of the replacement door latch and the labor fee. We had to pay for the cost of the initial service call. If you are having this problem, I would suggest that you contact Frigidaire. They will require that you have a diagnosis made by a certified technician. According to our technician, the flow chart for the Frigidaire front loading machines is inaccurate, so if they make an initital diagnosis of a faulty control panel you may want to have them contact Frigidaire tech support to double check the diagnosis. Frigidaire may help cover the cost of repair if your machine has a problem with the door latch.
Posted on May 09, 2008
  • 1314 Answers
SOURCE: Frigidaire Affinity front loading washer will not spin
send me an e mail at b4829@yahoo.com for futher info
Posted on Jul 10, 2008
  • 574 Answers
SOURCE: Affinity washer will spin as if off balance
well there's a counter weight that could be loose or broke or the support hangers for the tub may be broke or loose.
Posted on Sep 17, 2009
SOURCE: Frigidaire Affinity ATF8000FS gives me an error
I have the same code and problem...E48:Board thinks the PTC circuit is closed. Any help?
Posted on Aug 21, 2010
rabbitbrains
  • 575 Answers
SOURCE: my frigidaire affinity front load washer stopped spinning
Your door lock switch assembly has gone bad. It is an easy fix.
Posted on Sep 27, 2011
What is E58
Good Afternoon Friend,
I understand you are receiving an E58 code on your Frigidaire Affinity washer, model# ATF8000FE. The E58 states that it is a high current on the motor phase. This could possibly be a false code, as well. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Frigidaire Affinity ATF8000FE
E56
Hi Susan, this is JK. I understand that you are receiving an error E56 on your washer. This error E56 is indicating a high motor current, the motor has overheated. The washer motor will stop when it is overheated, allow the motor to cool down and attempt to wash again. If the problem persists, you would need to contact a service provider to test the motor, motor pulley, tub pulley and the bearings. Hope this helps!
Mar 24, 2014 | Frigidaire Affinity ATF8000FE
Frigidaire E57
Hello Daniel Huntley - Typically error code E59 indicates that that washer is not detecting a tacho signal for about three seconds. Contact a professional to move forward accurately. Certified technicia will need to remove the belt from the motor, spin the motor pulley, diagnose the speed control board and etc.
Jan 07, 2013 | Frigidaire Affinity ATF8000FE
I have an affinity washer, stackable, model atf8000fs1, it runs for 15 minutes and quits, help
sounds like it has a bad timing cycle when it reaches that point the catch for the next cycle don't engage if this is the case the timer will need replacing i suggest contacting a service dept hope this helps
Aug 30, 2010 | Frigidaire Affinity ATF8000FS
Fails to spin out after wash cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 30, 2010 | Frigidaire Affinity ATF8000FE
Frigidaire Affinity ATF8000FS gives me an error code of E48. Stops a few mins after cycle begins
Jul 24, 2010 | Frigidaire Affinity ATF8000FS
Will not spin
not advancing to spin cycle. usually mis communication between the user interface and central control unit. need a tech.
Jun 24, 2009 | Frigidaire Affinity ATF8000FS
Stinky washer
I had a similar problem with odor. I ran the washer on hot with a few cups of vingear in the detergent, bleach, and fabric softener trays and it helped a lot. Also, be sure to leave the door cracked open when you remove wet clothes, so the inside of the washer can air dry.
May 05, 2009 | Frigidaire Affinity ATF8000FE
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
