Question about Mitsubishi MSH09TW Air Conditioner
Air conditioner When in cooling mode, cooling unit shuts off after 10 min. with fan still running and flashes E3 on display.
  • 7 more comments
  • jicamo Apr 27, 2008
    starts on for 5 minutes and then shuts down.
  • CLUBKEV4U May 30, 2008
    I HAVE A FEDDERS WINDOW UNIT
    IT BLOW COLD FOR 5 MIN AND THEN THE COMPRESSOR SHUTS OFF AND THE FAN BLOWS HOT IF I TURN OFF UNIT AND THEN BACK ON THE COMPRESSOR COMES BACK ON AND WILL BLOW COLD FOR 5 MINS THEN SHUTS OFF AGAIN PLEASE HELP
  • Anonymous Jul 11, 2008
    blows for less than a minute then flashes e3
  • marksofd Jul 16, 2008
    Where is the thermostat switch, what do I check for, can i find a replacement easily, and can i replace it myself ??? Thanks.
  • Anonymous Jul 17, 2008
    Sometimes the unit wont even come on and when it does it runs for only 15 min.s maximum.
    Unit won't start often. gfi shows power. when unit does start everything works ok, but shuts off after 15 min.s maximum
  • Brute145 Jul 18, 2008
    I have a fedders ductlesssplit air wall mounted air conditioner which runs for a bit, then it cuts off showing an E5 error and that is only sometimes. When it does run constantly it does not cool the room. I cleaned the filters and still not cooling properly. I am curious to know what E5 is. It does not show anything in the manual
  • Anonymous Aug 16, 2008
    same problem as other people are having.
  • Anonymous Aug 20, 2008
    I have a Daytek Daewoo ASWH12A4/EL Airconditioner that does not start. As you switch on the display shows the temperature and then goes straight to E3. Can anyone help please?
    New Friend:
I managed to find the people who supplied the unit, it was still under warranty, and they said it was the thermistors (temprature probes, they replaced both of them) It is now working perfectly!
Posted on Sep 24, 2008
I just paid someone to diagnose mine which is doing the same thing. E3 on the Mitsubishi air con can mean a few things. 1. Unit is overcharging.
2.Faulty accurators
3.Electronic module.
Now this is all gobbledy gook to me but perhaps you might know more or know someone who does. I now have to pay this technition $75 hr until he fixes it.
Posted on Sep 23, 2008
    Problem Solver:
  • 6 Answers
Your ac is short cycling. compressor or board.
Posted on Sep 09, 2008
  • 86 Answers
1.check thermostate switch
Posted on Mar 17, 2008
6ya staff
SOURCE:
I turn on the unit and run with no cool air after 3 to 4 mins the unit shut down the fan go off and I get a constant flashing
Do a visual check on the air filter, inside coil for freezing and the outside unit for obstruction of air flow. Check your owners manual to decode the flashing light. Good luck!
Feb 15, 2016 | Heating & Cooling
Fault E3 Have same problem, fan works fine but will not turn on cold air. Display shows "e3". I have a remote, but do not see a button "c".
Try this : Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
Aug 09, 2008 | Kenwood KW85 Air Conditioner
What is a E4 code mean
Error Code:
E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System
will shut down.
E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling
operation will be locked out. Fan operation can continue to operate.
E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation
will be locked out. Furnace, heat strip, heat pump and fan mode of operation can
continue to operate but displays the last temperature set-poi
Dec 18, 2012 | Dometic 3313192.000 White Single Zone LCD...
The e3 light is on and its not cooling just fanning
The E3 error code, indicates that the water in the collection tank is full and needs to be emptied.
Turn the unit OFF & unplug it, before attempting to drain the tank. Once that is completed, the unit should operate as designed.
Hope this helped you and thanks for choosing FixYa.
Sep 07, 2011 | Royal Sovereign ARP-4010 Air Conditioner
I have a samsung air conditioner - model AQV24NS and after 10- 15 mins it shuts down both red & green lights start flashing. The only wayi can get it to work again is to shut off the main power suply...
Please check outdoor unit. Compressor or fan motor getting high amps due to overheat. Clean condenser coil. If still problem, replace running capacitor. If out door fan less rpm replace fan capacitor. In some unit 2 in 1 capacitor is there. So replace one capacitor will rectify fan and compressor problem. Thanks. Helpful?
Jan 09, 2011 | Samsung Heating & Cooling
Spw-kr254 sanyo wall mount. unit operates in heating , when in cooling will operate for a good 10 mins then fans stop running and on/off button flashes
Check your condenser unit is ful of dust? Clean it. And also weaken capacitor unit runs for 5 to 10 minutes only. Replace capacitor.
Jan 08, 2011 | Heating & Cooling
Carrier A/C in RV won't run
check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
Duro-therm rv roof a/c..model 57915.331...compressor coming on..fan not running..after a couple min. breaker trips....fan will not run on manual or auto...help,blackie williamson
Either your fan is stuck due to age or grime or is shot
if the fan does not provide cooling then the unit goes into thermal protection mode and shuts down
Jun 09, 2009 | Dometic Rooftop RV Air Conditioner
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Mitsubishi MSH09TW Air Conditioner Logo
1,072 people viewed this question
Top Mitsubishi Heating & Cooling Experts
NOEL
NOEL
vince
D. E. Hev
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
