Akg d1000e mic clip replacement id # - Audio Players & Recorders
4 Suggested Answers
SOURCE: Extremely weak RF from AKG WMS 60 Hand Held Mic
I don't know what you've tried already to improve the signal level, so i'll list a few things that migt help.
It might help to put new batteries in (with the right voltage) You probably did that already.
There is a GAIN pot on the mic, in the battery compartment under the ring that is screwed onto the mic. When you adjust the GAIN, there will probably be better SN-ratio, but it does'nt change the RF signal
You could also adjust the antennas of the receiver, or try to set a different frequency (depends on which country you live in, in some countries it is illegal to change frequencies) or turn off the SQUELCH on the receiver
If this does'nt help, you could look for a user manual and try to find a solution in it.
There are some other solutions to improve RF signal, but those are quite expensive.
Posted on Nov 09, 2008
  • 5 Answers
SOURCE: akg c1000s replacement grille
Maybe you could find a local music store that repairs equipment to replace the grill. Sometimes you can find parts on websites like Ebay.
Posted on Oct 28, 2009
  • 611 Answers
SOURCE: I have lost the metal clip on back of akg b29 L
Try giving AKG a call. They should have replacement parts.
Posted on Nov 02, 2011
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
AKG 120 to Tascam US-800 connection issues
There is no reason to use such a configuration with the US-800. I advise using a standard XLR mic cable. It's likely phantom power doesn't work over the 1/4" jacks.
Jan 26, 2012 | AKG Perception 120 Microphone
Nov 02, 2011 | Audio Players & Recorders
Hum which is made worse on touching top half of mic. clearly an earthing matter. engineer has checked bottom half but does not know how to get into top half.
I have the same mic, same problem. I disassemled the mic, put it back together, and the problem fixed itself. I can't explain exactly why.
To disassemble the top part of mic, turn the 2 plastic posts inside the mic clockwise.
http://www.akg.com/mediendatenbank2/psfile/datei/96/C4000b4055d1f13eb44.pdf
Mar 18, 2011 | AKG C4000B Professional Microphone
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
Akg c1000s replacement grille
Oct 07, 2009 | AKG C1000S Professional Microphone
AKG 414 crackle
Had the same problem. Check the ground (earth) is attached properly to the mic. This will cause the signal to be interrupted and can also cause a phasing problem. A lot of techs don't check that when you send them for repair
Nov 12, 2008 | Audio Players & Recorders
AKG C418 is not working!
it works its probably just that you dont have your drivers set up right same problem here with my usb mic you gotta go into sound and change the standard mic to the mic you want to use and if you have a web cam mic also hooked up you will want to disable web cam mic (not the web cam) in drivers these 2 mics are having conflict of interest
May 07, 2008 | AKG C418 Professional Microphone
Mic repair
Oh sorry, it was an AKG c418. However, shortly after i posted, i stared at the thing long enough and managed to get it apart, fix it and put it back together. thanks
Feb 28, 2008 | Audio Players & Recorders
AKG Perception 100 not working, at all
The problem is that your amp probably doesn't have phantom power. This mic requires phantom power to be supplied to it via the XLR connector. Most mixers and mic pres have that feature, but most guitar amps do not, I believe. Hope that helps...
Jun 08, 2007 | AKG Perception 100 Microphone
21 people viewed this question
 Grubhead
Grubhead
