Question about Panasonic PT-47WX51 47" Rear Projection Television
Convergence chip Someone is selling me a a 47" Panasonic rear projection TV, but he said the convergence chip needs repairing is worth buying? and how expensive is it to be repair?
  • 398 Answers
Legna just gave you the procedure for standard adjustments on an RCA TV. I have no idea why he would do that when you clearly stated that you have a Panasonic set. What you should do, if possible, is to go see the set playing before you buy it. If one of the convergence IC's has stopped working, there will be an arc of color toward the center on one or more sides of the picture. The picture should be almost normal in the center, and if the picture in the center is nice and bright with great color, and the screen itself is free of cracks or deep scratches, then the set is definately worth buying and having repaired. It is also quite believable that the set needs a convergence IC because by far, the majority of my service calls for projection sets are because of burned out convergence IC's.
Posted on Aug 31, 2007
    Scholar:
  • 53 Answers
Now is this what really is the problem is your friend's have a tech man tell him so? in any case you're looking at roughly $150-300 repair cost plus labor. but you can try the following your self by entering the service mode follow this steeps: Read the _ SERVICE MODE WARNING _ before proceeding. To enter service mode, push and hold the [Menu] button on the set. While holding, push and release the [Power] button, then the [Vol +] button. You will now have some information on the screen: "P0 V0" To actually be able to change these values, you must push [Vol +] on the remote so the information reads V76. Then pushing on the Channel +/- will change the "P" value. P1 - 3 are error codes. If there is a problem with the set that can be self-diagnosed, the "V" will report the code. These codes are available in the RCA repair manual. P4 - 7 control the horizontal size, shift, vertical size and shift. You may also find a summary leaflet for the service tech clipped somewhere inside the chassis. The procedures for getting into the service mode, as well as the service items of interest will be there. If you're attempting to adjust color or geometry errors, you'll need the Video Essentials DVD, Laser Disc or some other source of test material. Adjust the problems manually with any luck you might be able to get it back to normal. Good Luck!
Posted on Aug 30, 2007
SOURCE:
Colors overlap each other and looks 3d
This is symptom of bad convergence that happens due to failure of convergence output chips in tv, there are two big black chips attached with big aluminum heat sink that will be replaced to solve tv issue.
If you are not familiar with electronics stuff repair then call local tv repairman to replace above said chips to fix the problem.
Hope this will help.
Thanks.
Apr 05, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Need to replace the ic convergence chips but not sure how
U have tools like philip screw drivers,long noise plier and a soldering iron,soldering wick or desoldering pump and solders?U Know how to do basic soldering?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.U can go to You Tube type in convergence problems,will see a video by someone tutoring doing convergence board repair.
Jun 17, 2010 | Panasonic PT-47XD64 47" Rear Projection...
I have a blue double image on my panasonic pt-47wx49e projector tv. I've tried to adjust the convergence from the set up menu. But no matter how many times I try to adjust the green or the blue, only the...
If you go into the customer menu and select convergence and it is skewed you need to remove the light box and replace both of the STK-392-110 CONVERGENCE IC chips this set uses.
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET--I can post them here if you think you or someone you know can do the repair.
Most shops get 300 or more for this repair--if you buy the chips on Ebay (I can tell you the seller to look for there) they and any other parts should total under 30 dollars. The fact that the set is still coming on means most likely just the two chips need to be replaced and the set adjusted with the Panasonic remote for this set.
If you have questions or want the instructions rate this solution and let me know and I will post them here---I do this here for FREE.
SD TECH
Nov 30, 2009 | Panasonic PT-47WX49 47" Rear Projection...
I have problem with my convergence rear projection panasonic
most of the time you need to change the stk392-110 chips an ome resistors let me know if you need more help
Jul 31, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic 53" tv
Blue background lines with colors otherwise OK may be a loose or dirty blur drive potentiometer on small circuit board behind front grille and beneath front imerboard cover. These are hot-glued in place from factory but may be the cause f the problem. They're VERY sensitive.
If you have bowed blue lines instead of properly aligned colors, you probably have a blown convergence amplifier IC. These boards are no longer available so yours will have to be repaired. Some shops repair them but many send them out for 6-10 weeks. Fairly expensive too considering the amplifier chips are about $35 each (x2).
Jun 01, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I have a panasonic HDTV 1080i. seeing double images
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Feb 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic 47 inch Projection tv PT-53WX42F
Sounds like your convergence chips are going. Unless you are real handy with soldering iron I would suggest having a tv repair shop service it(probably cost $200-300). If you are handy then I believe the chips you need are Sanyo STK392-110. There should be 2 of them. be careful if you order them online, there are lots of chinese knock-offs out there.
Apr 19, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem
replace the stk-392-110 (x2) and any burnt resistors. cost 20$
Nov 19, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Convergence chip
Convergence ICs cost around 15-25 each there are only two of them. I would go ahead and replace both of them because if one goes the other one will follow shortly. I would make sure that it is just the convergence IC not something else, and if its over five years old dont pay more than $500.
Nov 04, 2007 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic PT-47WX51 47" Rear Projection Television Logo
193 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
