Question about Boating
Boat motors Have a 100 hp Johnson boat motor it is firing on the left side but not the right motor will roll over but won't start any suggestions it greatly appreciated
    Top Expert:
  • 43,014 Answers
Sounds like you have a bad power pack..
Posted on Jul 07, 2014
  • 23 Answers
SOURCE: I have a 50 hp 1975 Johnson outboard. When I turn
There is a switch in the control box that locks out the start unless you are in neutral. Open the box and put in a new switch,this is a safty device to keep it from starting in forward and throwing you out of the boat. Jim OMC retired Mech
Posted on Jul 07, 2009
finish line
  • 207 Answers
SOURCE: johnson 1998 175 hp motor seems to be in safe mode
U CAN DISCONNECT THE OIL RESOVIOR SWITCH THAT TAKE IT OUT OF SAFE MODE BUT IM LEANING TOWARD THE POWER PACK
Posted on Jul 13, 2009
Editor925
  • 285 Answers
SOURCE: oil mixture for a 70 hp Johnson boat motor?
If it is a 2-stroke motor than gas:oil ratio should be 50:1
Posted on Sep 04, 2009
Editor925
  • 285 Answers
SOURCE: 40 Hp Johnson outboard motors stalls out after a
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Posted on Sep 17, 2009
SOURCE: 20 hp evinrude boat motor will not start
broke key off of ignition trying to jump over, can't find wire to keep motor running, will start, but not stay running cause wired to toggle switch. can u help, please thanks, wayne (20hp johnson/evinrude
Posted on Nov 08, 2009
Has compression and fire but dont start
Remove sparkplugs and squirt some fuel in cylinders. Replace sparkplugs and start motor. If it fires up you have a fuel problem and a good carb cleaning should clear the problem.
Mar 16, 2014 | Light Outboard Motor Boat Bass Fishing...
I have a 100 hp Johnson outbound, its firing on the left bank but not the right. it will roll over but not start. any suggestions. thanks
The power pack on the right side is probably faulty or not getting power or timing from the engine.
Jul 21, 2013 | Cars & Trucks
I have a Johnson 70 outboard motor and I'm having
The moter has locked up is it 2sroke or 4sroke if 2 did you have oil in the fuel ?
Apr 29, 2013 | Boating
1997 50 hp Evinrude won't fire
Take off the top & expose the magneto clean with a fine grit sandpaper that should get fire to the plugs if still no fire u may have.to replace the points
Jul 23, 2012 | Boating
I usually don't recommend starting fluid but some brands have oil with them. You may have to dry the cylinders by getting them to fire with starting fluid.
You may have something else wet and grounding. Before using starting fluid spend some time with a hair dryer and try drying out the motor. Leave it sit in the sun with the cover off.
You should drain the carbs, drain the fuel line and gas tank.
Aug 01, 2009 | Boating
Johnson 1998 175 hp motor seems to be in safe mode
Jul 12, 2009 | Light Outboard Motor Boat Bass Fishing...
Jul 07, 2009 | Boating
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Boating Logo
63 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
