Logic platinum I have been trying to run logic platinum 5.5 on windows xp mode VMware player,it opens perfectly but when i press play it freezes and I get this pop up message 'Timer or midi output inactive. How can i solve this problem.
    New Friend:
Ang ganda ng kamay si alexia nga pala to
Posted on Jul 23, 2013
ziraffa
  • 827 Answers
SOURCE: Error when I try to use Windows Media Player 10 or 11
This error is generally the result of a corrupt or missing Custsat.dll file, usually located in the C:Program FilesWindows Media Player folder.To workaround this problem:
1. Remove the current Windows Media Player 10 install.
2. Download and install
Windows Media Player 11 for Windows Vista
or
wm_tn_wmp11xp.jpgDownload Player 11 for Windows XP
I tend to use VLC Player, as it plays everything I throw at it..
Hope this helps
Chris (ziraffa)
Posted on Jan 05, 2009
thetaocat
  • 122 Answers
SOURCE: Trying to find Owners Manual for eMagics' Logic
find them online, contact them; they will either call you or email you a PDF of the manual, the manuals are usually very large, so have plenty paper to print 200-500 pages or plenty memory to save. I always save the email for further reverence, emails are not saved on your hard drive. Most owner manuals are free.
Posted on Apr 23, 2009
siddhu8888
  • 26 Answers
SOURCE: Im running WQindows XP and have installed Roxio
please install the sp3 and try.
Posted on Nov 27, 2009
oldmanewtoys
  • 414 Answers
SOURCE: I have a laptop running Windows Vista, and can't
Corrupt file in program. Delete and reinstall program.
Posted on Feb 26, 2010
  • 2340 Answers
SOURCE: This used to work perfectly on windows XP. I now
Downloading means you retrive any files and save to your PC/Laptop from any web source!
Installing means you install any software/programs to run on your PC/Laptop.
As for your software "Photo Explosion 2.0" could not run on Win 7 due to software "Compatibility Issues".
You can try, using "Win 7 compatibility mode" installing older software read this LINK
NOTE**
"There is no guarantees older software will work using Win 7 compatibility mode!"
Hope it helps.
Posted on Nov 11, 2010
I run win7Pro & AG CreataCard Platinum 8 will not install..is my favorite card making program for family & friends, any help appreciated.
CreataCard Platinum 8 was written for XP and older versions of Windows. Changes in the OS make it difficult/impossible to install.
Do you have the 32-bit or the 64-bit version of Win7Pro? Click Start > Control Panel > System and Security > System. If the title reads Windows 7 Professional x64, it's the 64-bit version. (If it doesn't end with the x64, you have the 32-bit version.)
In any case, the best option is to try running an older version of Windows on another machine, a dual boot system or a virtual computer. With the Pro version of Win7, you can run a virtual XP for free (if your hardware can support it). Download and install Virtual PC and the XP mode package from Microsoft. (You'll need to set aside some memory for the virtual PC to run.) Then install CreataCard when running XP mode as if this is your only computer.
The only real problem is that you will not be able to have hardware installed on the virtual XP and the Windows 7 real machine at the same time. (So you can't share a printer.) Also, to share files between the two "systems", you will need to save them to external media (flash drive or optical disc, for example). Your motherboard and CPU need to support Virtualization. You have to turn this on in your BIOS on some systems. (Press Esc, F1, F2 or F10 repeatedly depending on your system right after turning on the system. If you miss the timing, shut down the computer and then retry.)
Other virtualization programs are Parallels and VMWare. However, with those programs and the other possible options for running CreataCard, you need a licensed version of the older version of Windows.
If you have the 32-bit version of Windows, you can try the Compatibility Mode. (Right click on the installer and choose Properties. Then click on the Compatibility tab and select Run the program as compatible with an older version of Windows. Apply the changes and click OK. Then right click on the installer again and choose Run As Administrator.) You may have to repeat this on the program icon after installing. However, the compatibility mode doesn't always work even if you have the 32-bit OS (and thus don't need the signed driver).
An alternative is to upgrade your software to one that is Win7 compatible. I'm not sure which of these Broderbund design and print products are most similar to CreataCard: http://www.broderbund.com/c-6-design-print.aspx . However, you will probably not be able to open old documents.
I hope this helps.
(XP mode is available with Win7Pro and Ultimate. At my house, we have two computers with Win7Pro with one running XP mode. At least once, the virtualization was turned off during a BIOS update and XP mode failed until the setting was corrected.)
Dec 24, 2011 | Broderbund American Greetings Creatacard...
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I have upgraded from XP professional to widows 7 now I cannot install my Print Artist grande suite. please help Lorraine
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties.
Select Compatibility tab and select the Windows XP version.
This should work but if it doesn't there is nothing you can do except complain to Sierra to make a fix for it.
goodluck
Apr 08, 2011 | Sierra Print Artist Platinum
Can i install windows-xp on my laptop which is currently working on windows-7 and use both of them.
Yes you can install windows xp in windows 7.
Windows XP Mode is a virtual PC image of Windows XP Service Pack 3 that could be run on Windows 7 Professional, Enterprise or Ultimate versions. Applications installed into Windows XP Mode could be run in Desktop Mode or Seamless Mode. In Seamless Mode, applications appear to run natively within Windows 7, but they are actually running inside the Windows XP virtual machine. Windows XP Mode might also provide additional integration that traditional Virtual PC images might not be giving. Applications installed on the Windows XP image could be exposed to the Windows 7 Start menu. Applications run in seamless mode is having automatic access to the Windows 7 known folders like Documents, Pictures, Desktop, Music, etc. Also the Cut-and-paste is enabled between native Windows 7 applications and those running in Windows XP Mode. Applications running in Windows XP Mode might also access your Windows 7 network connection and USB devices.
Nov 30, 2010 | Computers & Internet
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
My Windows internet connection is not working in my virtual Windows machine (VMWare Fusion 2.0.5) I am running Windows XP Home through my MacMini using Fusion. Always worked til now. Laast time I...
You should add an ethernet adapter to your device list. Try to play with the VMware options: Bridged connection or through the host. Your setting may have changed.
Note: I have no experience with Macs, nor with Fusion. But I used VMware station to run Ubuntu on top of Windows XP. So do be indulgent with my suggestions and say: Father, forgive him for he knows not what he is doing.
Aug 30, 2009 | Computers & Internet
Windows xp screen freeze
try reinstalling vmware and XP if that does not work you should get parallels
Mar 16, 2009 | Microsoft Virtual PC 7 with Windows XP...
My gogear freezes every couple of minutes!
Update the firmware first
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Updated using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 11, 2009 | Philips GOGEAR SA6045 MP3 Player
Zoombini's Logical Journey won't start up
If the program produces an error right after hitting the Play button, I had success by launching the file Zoombinis Logical Journey.exe in compatability mode using Window 98 / ME and 640 x 480 resolution. The shortcut that is created during install points to TLCRUN.EXE which was what caused my error.
Feb 18, 2009 | The Learning Company Zoombinis Logical...
Zen micro firmware problem
I just got a ZEN Micro 4GB player for free due to Firmware problem. This totally fixed the firmware issue. Windows XP PC with Media Player 10 and the latest driver and firmware from creative. Once I had all that I plugged in my player, let it recognize and then re-flashed to latest firmware. BAM now the play is working perfectly and I can sync music to it. Thanks for the fix.
Jun 25, 2008 | Creative Labs Zen Micro MP3 Player
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
