Question about Garden
Replace stihl BG 65 off switch
Replace off switch on bg65 stihl blower
5 Suggested Answers
  • 257 Answers
SOURCE: Kill switch on Stihl BG 75 leaf blower not working
when engine cool,, spray wd 40 into the switch and work it a dozen or so times and clen it out
Posted on Aug 12, 2009
  • 432 Answers
SOURCE: Need to know the gas to oil mixture for a stihl bg
2oz oil / 1gal gas is a good rich mix. you can go up to 2oz oil / 1 1/4 gal. gas. Use only good quality oil.
Posted on Nov 07, 2009
rwvanlue
  • 486 Answers
SOURCE: stihl bg 55 blower runs good for 5 min. then loses power
1) carburetor gaskets/diaphragms may need to be replaced
2) ignition coil may be breaking down when hot
3) check compression when cold, then after it stops, when hot
4) could have a vacuum/pressure leak
*I would investigate carb first
Posted on Nov 08, 2009
2strokeJim
  • 577 Answers
SOURCE: I need to replace the muffler on my Stihl BG 65 blower as therepairman left the baffle off and it sounds like a Harley.
Is this a 4cycle blower or 2 cycle ? if its a 2 cycle the baffle plugs up from low grade 2 cycle oils, so he prob. pulled it out because your eng would not rev up cause of it being plugged, he should be able to find you one, personally I would run with it the way it is...the better your eng breathes...the better it runs!
Posted on Nov 14, 2011
How can i fix if the engine wont start??
check /replace the plug
check for spark( stop switch is working)
check choke position
clean air filter
service carby
May 25, 2015 | Stihl Garden
How do I adjust the carb jet when it wont run?
Carl,I bought one of these,the engine locked up and it couldn't be fixed,Stihl's are junk,went and bought a huskavarna from Lowe's,if buy your spark plugs,get them at Autozone,Stihl has a high mark up...
Mar 23, 2015 | Stihl Bg55 Bg65 Bg85 Leaf Blower Fan
Stilh bg55 spark plug setting
Hi
Stilh recommend 0.020 inch (20 thou), however I have found that 0.025 (25 thou) or 0.6 mm provides a better start and run arrangement.
Regards
Jacko from down under
Apr 26, 2014 | Stihl Bg55 Bg65 Bg85 Leaf Blower Fan
Where go the ground cable in the stihl bg 72
it connects to the metal body via a small lug spade type connector
usualy this ground wire is used to by the switch to turn it off
Apr 19, 2014 | Stihl Blower Bg72 Hand Exhaust Muffler...
Leaf blowers
Your local Stihl dealer would be the best place to get a carb, but you can save money by shopping round online. I have used L&S engineering in the past. But it depends where you are in the world. :)
Feb 12, 2013 | Stihl Garden
Stihl BR 400 causes for no spark
check the shire pin on the flywheel and also check your on/off switch
Aug 02, 2012 | Stihl BR400 Backpack Leaf Blower
Dummy me replaced the fuel filter on a Stihl BG65 leafblower and didn't pay attention how the fuel lines hooked up. I would appreciate any help you can give me. Thanks
the one leading out the side of carb at the primer bulb is fuel line other one ie return line dont mix them up take the filter out to make sure witch line is the right one
Oct 16, 2010 | Briggs & Stratton Garden
I have a Stihl BG65 blower which starts well and idles well but th RPM will not increase when the throttle is opened & the throttle valve is opening.I Have asked three repairers for a diagnosis and get...
Had this problem after about 100 hrs over 5 years. The fix was to remove the muffler output filter (spark arrestor?), which gets clogged with carbon and clean or replace it. It is spark plug size on the output of the muffler. To clean it, heat it with a torch to barely red hot to burn off the carbon, and brush with a small wire brush.
Aug 29, 2009 | Garden
Aug 12, 2009 | Garden
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
