Question about Sewing Machines
Brother lt2b8323 my thread keeps unravelling what can I do
4 Suggested Answers
  • 30 Answers
SOURCE: Bobbin unravelling on prolectrix 8 stitch sewing machine
did you put the bobbin thread in the tensioner? that would be the cut in the side of the bobbin case to pull the thread under the tensioner. if not it will cause problems. but if the top thread is looking good then the top thread is the problem, thread the machine with the presser foot up to let the thread into the tensioner, if it looks good on the top and not the bottom it is the upper thread if it looks good on the bottom and not the top it is the lower thread
Posted on Aug 22, 2009
  • 1116 Answers
SOURCE: I can't seem to get my tension right. It keeps
Check the needle to be sure it is the correct size for the type of fabric you are sewing and does not have a burr on the tip.
Raise the presser foot when threading the machine and this will open the tension control so the thread can properly seat into the control and form a proper stitch.
When the machine is threaded with the presser foot down, the tension control closes and the thread cannot enter as it should. In this case, the bobbin thread is the only thread with tension.
Posted on Mar 24, 2010
SOURCE: pfaff 134 thread unravels
try changing the needle--make sure to use every thread guide
try a different thread
check for any burrs on the needle plate or on the bobbin case
clean under the needle plate & in the bobbin area for lint or loose
threads
Posted on Aug 17, 2012
How do I thread the nedle
the easiest way for me to thread a needle is: 1. check to see which direction the needle eye is facing... some machines had the eye so you threaded it from the side... nowadays it is usually from the front... the opening facing you when you sit in front of it. 2. wet the end of the thread-about a half inch or so.. then take very sharp scissors and cut the very end of the thread off, but leaving some of the wet tip there... the moisture keeps the thread from unraveling as it goes through the needle eye. 3. now carefully slide the thread end through the eye. 4. Once it is through, pull at least 8 inches of the thread through (so it doesn't pull back through the needle when it first starts sewing the fabric)
Dec 28, 2014 | Sewing Machines
Why is the upper spool of thread not turning, thread is not going thru machine?
The way you are explaining your problem makes me think your. spool is knotted. Check it buy pulling out and unraveling the thread. This may answer your question. GOOD LUCK FRIEND.
Nov 17, 2014 | Brother PE770 Computerized Sewing Machine
My top thread keeps snapping
Sounds like your tension is set too tight for the thread. Or you are using a poor quality thread that unravels and keeps knotting as it comes through the needle. Or you have a block between your tension discs. Pull a thicker thread through the discs to clear anything that is there.
Oct 06, 2014 | Sewing Machines
I'm using Brother Poly thread on my Brother PE-770. Everything was fine until I changed needles. I followed the directions exactly. But now, when I embroider, my thread keeps unraveling and the needle...
Please check your needle position, putting it in backwards is a very common error, the FLAT side of the needle shank should be towards the back. Also be sure that during the transition, that the bobbin thread did not get misaligned.
So, make sure the needle has the flat side to the back, and rethread your bobbin thread through making sure it is correct.
Jun 11, 2014 | Sewing Machines
Top thread unravelling
Turn your spool around. You've got the little thread catch on the spool on the side it unspools from. Make sure it's the other direction.
Sep 30, 2012 | Janome Sewing Machines
Needle string wont stay connected
You are missing one of the steps in your threading pattern. Sometimes it is going the wrong direction when threading the machine. Check your owners manual or go on line to the manufactures website and it will give you tips on what to do.
Sep 22, 2012 | Euro-Pro 1260DX Mechanical Sewing Machine
Pfaff 134 thread unravels
threads
Aug 16, 2012 | PfaFF Sewing Machines
Discoloration on thread while embroidering
check for burrs around the needle plate areaa & in the bobbin area or any where the thread passes
Mar 08, 2012 | Brother PE770 Computerized Sewing Machine
I can't seem to get my tension right. It keeps skipping and putting loops on the under side of fabric and the thread keeps unraveling and breaking . Tacsew T111-155
Mar 24, 2010 | Sewing Machines
Jul 29, 2009 | Sewing Machines
Sewing Machines Logo
13 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
