Question about LW Scientific E8 Fixed Speed Centrifuge
Will not spin
I just used it a few days ago with no problems and now it will not spin. It turns on though. It seems to lock and I even tried changing the fuse.
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
2001 ford focus starter interlock
You might have a bad cable that runs from the shifter to the ignition lock. This is how the gear shift is locked when the key is turned off. When the cable starts to go bad this is what happens. Try disconnecting the cable and then try to crank the car. Good luck.
Feb 03, 2013 | 2001 Ford Focus
Final spin cycle doesn't spin
CHECK YOUR PUMP. IF IT'S CLOGGED OR BAD. IF NOT CLOGGED OR GOOD, YOUR MOTOR CONTROL BOARD IS BAD. GOOD LUCK
TIMOTHY 714-334-1998
Aug 04, 2010 | Frigidaire ATF6000ES Front Load Washer
97 odge neon will not turn over
any neon almost has a security system some times it will trip try using the key to un lock the door that will reset the system then start if nothing try the fuses under the hood one is bound to blow and wont let u start the car
May 29, 2010 | 1997 Dodge Neon
Dash, wipers and door locks didnt work, replaced fuses and it seemed to fix the lproblem, dash lights went out a few days ago and now it doesnt turn over or even grind when i trlyl to start it,
SOUND LIKE DEAD BATTERY OR LOOSE OR CORRODED BATTERY CABLES.HAVE BATTERY TESTED USING A DIGITAL VOLT METER.BATTERY VOLTAGE SHOULD BE 12.5 VOLTS IF NOT HAVE BATTERY CHECKED AND CHARGED.IF BATTERY WAS NO GOOD.HAVE ALTERNATOR CHECKED OUT.TO MAKE SURE IT IS CHARGING BATTERY.TO KEEP FROM LOCKING OUT YOUR RADIO.TURN IT OFF BEFORE DISCONNECTING BATTERY CABLES.
Feb 13, 2010 | 2001 Kia Sportage
1991 190e 2.3 mercedes key wont turn at all.
hello,good day,seems your steering lock mechanism is defective,or you can try to rotate your key, with patient ,maybe it turn,but you need to replaced the mechanism,ty
Jun 09, 2009 | 1993 Mercedes-Benz 190
1997 Sonoma driver's door key won't turn
need more lube and heated garage and to operate door lock plenty of times to free up binding lock
Jan 26, 2009 | 1997 GMC Sonoma
LW Scientific E8 Fixed Speed Centrifuge Logo
449 people viewed this question
Top LW Scientific Science & Laboratory Experts
William McMath
Tom Chichester
Are you a LW Scientific Science and Laboratory Expert? Answer questions, earn points and help others
