Mitsubishi srk35zj s
Flashing amber light and no cold air. I think it is the outdoor unit that's broken
  • 3 Answers
SOURCE: The fan in the outdoor unit does not work while the AC is on.
these motors are famous for the inyernal fuse blowing in the fan motor. check continuity between the red and blac wires. if there is non the fuse is gone. These motors are fairly easy to take apart and change the fuse . hope this helps
Posted on Sep 01, 2008
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
SOURCE: Flashing amber lights
it means that the flame sensor is not sensing a flame. If the flame is present and nice and blue the flame sensor is probaly dirty. Remove the flame sensor and lighty sand it with sandpaper.
Posted on Dec 25, 2008
  • 215 Answers
SOURCE: how to repair Samsung AQV 12 FAN Air Conditioner
You can turn off the Thermostat, and the powers switch on the furnance and turn the breaker off in the breaker box wait about 20 - 30 minutes and turn the breaker back on, and the power to the furance back on and the thermostat, this should reset the system.
Melvin
St Louis
Posted on Oct 04, 2009
  • 6 Answers
SOURCE: air con indoor unit is flashing 6 times out door is off
Please specify the make and model of your unit.
If this is a LG inverter model.
The six flashes of the indoor unit light indicates a CH 06 alarm.
This alarm state indicates that the indoor unit pipe temperature sensor has measured a temperature out of range or the unit is protecting itself from this low temp state. Indoor unit coil temperature to low. Should it have reached a temperature of -5°C for longer that 30sec it will switch the machine off.
It could indicate that the unit refrigerant charge is too low or the sensor has gone out of calibration.
It should measure 5kΩ @ 25°C
Posted on Mar 22, 2010
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Mitsubishi air conditioner flashing timer light flashes twice
Switch the polarity of the control voltage...make sure it matches with the indoor & outdoor unit
Dec 18, 2013 | Mitsubishi Heating & Cooling
Indoor unit start up as if the unit is fine then as soon asthe compressor is about to kick in (after 10 or 20 seconds) the green light on the front of the unit start flashing and the unit shuts down. went...
get the owners manuel and check q&a there should be a section that deals with the codes. the different sequences can help you trouble shoot. be careful the codes are not always correct. contact mitsubishi if you can't find. if all else fails call a repair person
Aug 06, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Have a Mr Slim. Air comes out but not cool. The green light was flashing. Turn the unit off and then back on and it stopped flashing, but still not getting cold air. Cleaned out the filters as well
i have vast history with this type of unit its like working on a computer all controls are microprosser based send me m# and s# of indoor and outdoor units might be able to help.
Jul 03, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have a mitsubishi air conditioning unit model MUH-12v. The fan on the machine outside has stopped and of course inside the air is not cold. Could this be a problem with replacing the gas or could it be a...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Aug 30, 2010 | Heating & Cooling
Fan @ compressor wont run,one light is flashing
flashing light is showing an error code. if the unit is under 5 years old it will be covered under warranty.. if you want you can try and reset the power by turning it off at the isolator next to your outdoor unit, leave it a couple of minutes and switch it back on. this will reset the fault code, if the flashing light comes back there is a definite problem, if it runs the fault may have been caused by a power surge or something
Dec 22, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
My mr slim is not blowing cold air, just warm, and a message P8 is flashing
P8 means "Abnormality in Outdoor Unit"
Possible causes
1 Wrong wiring of Indoor/Outdoor connection
2 Reverse Phase
3 Protection Device operated
4 damaged Outdoor coil thermistor
Aug 05, 2009 | Mitsubishi Heating & Cooling
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
