Question about Aqua Vac Tiger Shark
Power supply Need a replacement for an AquaVac P/N 30000 DCZ. Have no idea how old the unit is and cannot find anything. On the internet.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 77 Answers
Find it on ebay
Posted on Jun 04, 2015
2000 daewoo leganza is running 30000 rpm in high gear on the highway is that right
You mean 3000 not 30000, before you change anything, check the engine with a good scanner.
Mar 12, 2013 | Cars & Trucks
Desktop not receive a current
If you mean Power, then your psu (power supply unit) has most-likely gone bad. This happens a lot when a computer is as old as this model is. If you have no other choice than to replace the power supply, be sure to use dell in the search, models of this era did not have an opening on the back to accommodate a power (on/off) switch so you must get a replacement that will fit the case and not need an opening where there is not going to be one.
If you meant anything else, you need to explain better.
Nov 27, 2011 | Dell Dimension 8200 PC Desktop
Power button won't start
It is possible that your power supply unit went out and will need to be replaced. Also the power button itself may have gone bad as well. It is either one or the other. Power Supply Units are located inside the box of your computer
It may be a good idea to take this in to a local shop to have this done if you have never done this before. Power button switches look like this.
Depending on your computer the power supply unit and power switch may be different as well. If you know what you are doing you can replace these pretty easily the degree of difficulty is about a 3 on a scale of 10 so not that hard all you have to do is plug in everything that came out and remember where the wires go. Mark them so that you will not forget I use a b c d on and on for each part or wire.
You can obtain a new power supply unit pretty cheap. Just take the old with you when you go to buy one. If you go online to buy one just make sure that you have the same one match the case numbers and you should be fine. Most power supply units are ATX it will tell you on the old one. I would start there and change this out. Thanks for using FixYa! please vote for me. John
Mar 13, 2011 | MPC Computers MicronPC power supply - 220...
Need a replacement power supply, or at least need to know what input (volts and amps) the drive itself will take
Generic replacements for Seagate external drives are are pictured with a circular cross section plug with a yellow tip. They are rated at 12V 2A. They can be found on both eBay and Amazon.
If they look the same as your old supply, anything with that rating should be suitable.
There should be a sticker on the old unit with it's electrical characteristics, power ratings in and out.
Jan 31, 2011 | Seagate ST3500641CB-RK 500 GB FireWire 400...
Turns on but does not move.
Thank you for posting your question here on Fixya.com.
Your problem could still be in the power supply, cable or motor unit. The motor unit is the most likely problem. For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up
If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin. While your cleaner was made by Aquavac (Hayward) they work very much the same way.
It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Aug 09, 2010 | AquaVac Tigershark Plus Robotic Automatic...
Aquavac Tiger shark won't operate
The power supply powers on even when it doesn't output any voltage, so it's kind of misleading. You should have the power supply checked or you can do it yourself if you have a multi-meter, by measuring the output and making sure there is 24V.
Jul 17, 2010 | AquaVac Tigershark Plus Robotic Automatic...
Aquavac 42 tankless water heater: we cannot find a source for parts in US. Please help
Hello aknapton:
I just removed a working aquavac 42 from our home and upgraded. You can have the whole unit if you would pay for shipping.
It worked when we removed it. It was fussy about the standing pilot and had to clean the thimble jet a lot (dirty propane) but it did work. let me know. norm@finetuningauto.com
Jun 03, 2010 | Water Heaters
Praktica dcz 8lm camera: when turned on the light comes on for a second then goes straight back off again. won't take pictures or allow you to view pictures on pc
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 13, 2009 | Praktica DCZ Digital Camera
Tiger shark will not move
The motor that drives it forward and back is seperate from the fan and is defective unless your stuck on the main drain the motor unit needs replacing.
Mar 14, 2009 | AquaVac Tigershark 2 Commercial Vac with...
LG L1715S TFT power issue
Change out C202- 680 uF 25 Volt electrolytic capacitor. Replace with 25 volt or higher. Observe proper polarity when replacing cap: (-) goes to the side with the black mark, check old cap before removing it to see. I just fixed the same monitor today.
Dec 04, 2007 | LG Flatron L1715S 17" LCD Monitor
Aqua Vac Tiger Shark Logo
166 people viewed this question
Top Aqua Pool & Spa Experts
Larry Maranto
Shehu Pro
Shehu Pro
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
