Hoover hnf7147 willnot drain.checked filter ok and took pump to shop who tested it and said electrically its okay.
2 Suggested Answers
  • 4 Answers
SOURCE: hotpoint WF541 fault
washer wont fill with water
Posted on May 03, 2011
I recent bought 1998 4×4 v8 dodge durango catlic converter is off recent tune up took to shop for dynastic computer check not a code one came up now what?
What kind of problem are you having with the truck? Things like spark plugs need replacement or fuel pump, clogged fuel filter willnot cause codes in most cases.
Sep 23, 2015 | Dodge Cars & Trucks
Hoover nexus 8 1400 washing machine not spinning
if u cant unscrew it somethings jammed in it ,force it or pull the pump houseing apart
Jan 17, 2013 | Hoover Washing Machines
Whirlpool washing machine AWM 5100 has stopped going thru the full cycle.
My machine did a similar thing and in my case, it was debris in the filter. It took several clear-outs before the object appeared.
Mar 21, 2012 | Washing Machines
F02 error Pump Filter hoses all ok. Whirlpool duet front load.
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My GE dishwasher Model # GSD2200GO2WW will not drain. I took it apart cleaned out the food particles that were in the filter basket and checked the hoses... put it all back together... Still won't drain....
did you check the drain pump? if you remove the pump and take an extension cord and cut off the end and add two connetion terminals to the end plug em in then plug them to a wall outlet you willbe able to tellhow well your pump is actually working if your not electricly handy you might be best to call a technician btw use a shop vac to remove the water before you remove the drain pump hope this helps
Apr 29, 2010 | GE 24 in. GSD2220Z Built-in Dishwasher
Hoover ultima code F-02 flashing
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Jul 17, 2009 | Washing Machines
Wont drain water ,and wont spin model hoover 800rla maybe 4 years old? cheers frankm
have you checked filter and also check for foreign objects in pump impellor - that is the usual problem.
if both of these ok, then check continuity thro the pump windings
Aug 05, 2008 | Hoover Washing Machines
Hot point washing machine machine spins water does not pump out, took pump off and wired up independently it works, any suggestions? please
If the pump works then there may be a blockage between the drum and the pump or between the pump and the drain.
See if you can blow down the drain pipe to eliminate this possibility. If the drain side is OK check for blocked filters. Also check that there is power to the pump during the pump-out part of the cycle. If there is no power you will have to investigate the programmer and associated electrical components.
May 02, 2008 | Washing Machines
Pump issuse
The service manual is at:
http://136.166.4.200/contents/Laundry/WM1814/WM1814_Service_Manual.pdf
1. Press the SPIN SPEED and SOIL LEVEL buttons simultaneously.
2. Press the Power button, while the above condition. Then buzzer will sound twice.
3. Press the Start/Pause button repeatedly to cycle through the test modes
If it's pressed 10 times, the drain pump turns on.
Oct 09, 2007 | LG WM1812C Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
