Sharp 27f630 LA TV SE ESCUCHA Y CAMBIA DE CANALES PERO NO SE VE LA IMAGEN ECEPTO LOS CARACTERES
4 Suggested Answers
  • 2318 Answers
SOURCE: Por Favor me gustaria que
Podrias proporcionar el modelo completo de tu plasma?
Cuando proporciones el modelo te indicare donde esta la falla y tambien donde comprar la parte(s) para reparar tu TV.
Posted on Sep 12, 2010
TV #1
  • 129 Answers
SOURCE: El screem del Tv
Necesitas cambiar un tablero que se llama DMD module. Cual es el modelo del TV?
Posted on Dec 18, 2010
bbl242003
  • 1637 Answers
SOURCE: Buenas noches, tengo una hitachi
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
Como puedo programar mi contro de dish, para poder cambiarle a otro canal, nose que le paso pero no puedo mirar ni el menu de dish y al querer cambiarle de canal se cambia a componente 1 , video 1, video...
Hola Popysateaga, mi nombre es Kim y formo parte del departamento Social Media con DISH. Se que a este punto quizas ya no necesita de nuestra ayuda pero me gustaria contestar su pregunta por si en un futuro llega a necesitar la informacion. Cuando el control no responde con la programacion de DISH pero cambia los canales de la TV significa que el control no esta bajo mode Satellite. Si nota, en la parte arriba del control tiene 4 botones transparentes/blancos usted sabe bajo que modo esta el control al tratar de cambiar canales y el boton de 'TV' se ilumina ya sea rojo o verde. Para poner el control en SAT Mode de nuevo solamente Oprima el boton de SAT localizado en la parte de arriba del control por 3 segundos. Si necesita mas asisencia se puede comunicar conmigo a kimberly.escobar@dish.com
Dec 26, 2012 | DISH Network IR Remote Control
Tv lg 32ld330 enciende con sonido y sin brillo
Mi tv lcd es marca LG modelo 32LD330, al encenderlo se escucha y cambia de canal pero el video lo emite a mitad no da la imagen completa que puede ser?
Aug 18, 2012 | Televison & Video
Por Favor me gustaria que me respondierais a la mayor brevedad posible y en español. Mi lg pdp42,estaba funcionando perfectamente y de pronto se escuchó un ruido,como cuando se va la luz,como si...
Sep 12, 2010 | Televison & Video
Nose ve la pelicula osea la pantalla
disculpa pero my pantalla no se ve osea las perliculas y ya puse el switch pero la imagen de la pelicula no se ve solo quita la leyenda del freno de mano y la pantalla se quda en negro pero si se escucha
Jun 12, 2010 | Pioneer AVH-P5700DVD Car DVD Player
La imagen se pierde y se frisa no trabaja el control
usted tiene problema con el optical block , desafortunadament esta reparacion cuesta al rededor de $400-$500
Apr 13, 2010 | Samsung HLP6163W 61" Rear Projection...
LA consola arranca , y se escucha el sonido PERO NO SE VE
la buena noticia es que sirve todavia y solo es un problema de video.. tienes que quitar el ps3 todos los cables de atras y volverlos a conectar despuyes de un minuto y si es posible conectalos en otro input del televisor.. si no cambia el cable por otro.. o tratalo en otro televisor.. por ahi esta la solucion ya me ha pasado antes.. por favor dale click a que mi solucion te ayudo.. me avisas
Dec 27, 2009 | Sony Playstation 3 (PS3) Console
Image dosent turn on
necesita una PCB de T-Con. Estas una PCB que reprodicir la video para la pantalla de LCD.
Se venden unos en Ebay pero si no esta Technico es mas mejor que Se vende la Televisor.
permite me espanol por favor!!
May 27, 2009 | JVC LT42P789 42 in. LCD TV
Necesito data eeprom de tv rca 27f634t chasis a al encender pocos
cambiale el flyback y ponle la memoria original de vuelta. cuando encienda trata de ajustar el control de screen en el flyback hasta el punto en que cuando cambies los canales no se apague. creeme que esto me tomo mucho tiempo en encontrarlo pero al fin lo arregle. The Tech
Apr 05, 2009 | RCA 27F634T TV
Televisor
Decime el modelo de televisor (numero)
Un detalle tonto no pero Fijate que los parlantes no esten en MUTE
Acordate que el TV debe ir en canal 3 (ponelo a mano desde el TV)
Cuando tengas imagen, TODO A MANO prende y apaga la caja digital
Tambien apreta en el DVD o VCR la tecla TV/Video
Prende y Apaga tu DVD/VCR en esa misma operacion
Que pasa si pones una pelicula? No se escucha pero se ve?
Chequea el sonido desde el menu de tu tv, fijate sino hay un boton que dice MUTE
Oct 19, 2008 | Car Audio & Video
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
