Question about Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
Server disk full error - Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
Incorrect number of bytes written to disk
A search of the Oracle Metalink site ( http://metalink.oracle.com/ ) for the ORA-27063 and ORA-19502 errors returns Oracle Document ID 271511.1. This note indicates the hard drive of the Oracle server is full.
Resolution:
Free up disk space on the Oracle server. Refer questions regarding the correct way to clear files from the Oracle server to Oracle support.
http://www.symantec.com/business/support/index?page=content&id=TECH38253
Apr 15, 2015 | Computers & Internet
Server disk full in bizhub 420
malfunction was detected cs remote care c2403
Aug 21, 2012 | Konica Minolta bizhub 420
I have to format IBM server model no MT-M-8648-IIS by using window server 2003 but the error showing Hard Disk not traced out
Your hard disk may be faulty. If the BIOS cannot detectthe hard drive then it is faulty and you need to purchase a new hard disk before you can install Windows.
Aug 18, 2011 | IBM xSeries 226 Server
What is error 4? and how to solve.balance is stuckedup
What does particular error code mean "General failure". Particularly for "General failure", the SFTP server should provide you more details, that you will see next to "Error message from server". Unfortunately, SFTP server shipped with OpenSSH (or Sun SSH) does not. That is, why you see there just "Failure" (very useful).
Some situations when OpenSSH (Sun SSH) server issues this useless error message:
a. Renaming file to name of already existing file.
b. Creating directory that already exists.
c. Moving remote file to different filesystem (HDD).
d. Uploading file to full filesystem (HDD).
e. Exceeding user disk quota.
thank you
Aug 02, 2011 | Computers & Internet
Just showing roundcircle with the number 507
Erro 507 is defined as "The method could not be performed on the resource because the server is unable to store the representation needed to successfully complete the request. There is insufficient free space left in your storage allocation. "
Basically, the webservers hard disk is full. If it's your server, free up some space. If someone elses, contact the administrator and let them know about the error
Mar 05, 2011 | Computers & Internet
Konica Minolta bizhub reads "server disk full": how to unfill server disk? or how to fix?
CAUSE: Machine memory is corrupt and the max out time needs to be increased.
SOLUTION: Perform a Data Clear:
1. Enter the Tech Rep mode.
2. Press System 1.
3. Press Initialization.
4. Press Data Clear.
Also browse to the NIC, enter Admin mode and set the connection timeout for E-mail to 300 seconds.
Apr 23, 2010 | Konica Minolta bizhub C351 All-In-One...
How to create my hard disk as server like a website in my lan..............
you must install IIS (internet information service) or you can install wamp (mysql+ apache web server + php)
Jul 08, 2009 | Microsoft Windows XP Professional SP2 Full...
Server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
Mar 02, 2009 | HP ProLiant ML150 G3 Server
02A2: BMC System Event Log(SEL) Full
In HP prolliant server sets, setup also logs system events. This error is due to that log. Enter setup, trace log and clear all events.
Jan 28, 2009 | HP Compaq ProLiant ML110 G4 Server
COULD NOT LOAD OS - TRIED 2000 & 2003 SERVER
Reinstall OS without repairing. Sometimes people make the mistake between a choosing repair and a full reinstall. Also backup any files before doing so.
Sep 20, 2008 | Acer Altos G530 Server
Konica Minolta Bizhub C364 Color Copier / Printer / Scanner Logo
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
