Question about Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
Server disk full bizhub
Server disk full when scan to e-mail
SOURCE: Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
Posted on Mar 09, 2008
SOURCE: Cannot Scan To E-Mail
How to set up the machine for SMTP authentication. There is no selection to enter the information in network setup on the machine.
Solution
CAUSE: Incorrect soft switch setting.
SOLUTION: Perform the following:
1. Touch utility button
2. Admin. Management
3. Admin. 2
4. Software SW
5. Enter the soft switch mode 380. Set bits 6 and 2 to 1.
6. Re-start the machine. The SMTP settings will now appear in the network setup of the Admin 2 mode to allow entry of the user name and password.
Posted on May 19, 2008
herminio_hal
  • 210 Answers
SOURCE: how to set scan for a new person on bizhub c351
If you know the ip address of the copier printer, it will be easier for you to add e-mail address. open the internet browser and type in the ip address. admin password 12345678. or use public. Click the scan tab.
Posted on Jul 09, 2009
  • 51 Answers
SOURCE: Can get LDAP search working on BizHub 350 Multi function copier
the smtp serwer wos chench u nead to setup scan for email whit new seting of smtp
Posted on Aug 30, 2009
  • 158 Answers
SOURCE: HI , i have the problem with my Scan to PC to scan
this would be on a domain then
1 open the default domain controler security setting
2 local policies
3 under security setting for microsoft network server set: digitally sign communications from always to disable
so with digital sign on the server the scan jobs are not digitally signed and will be rejected by the server.
or you could set it up to scan ftp or email if you have either one of those type of servers in the buiding they cant be external servers
Posted on Oct 22, 2009
Server disk full in bizhub 420
malfunction was detected cs remote care c2403
Aug 21, 2012 | Konica Minolta bizhub 420
Bizhub 352 not scanning to emails
Check your DNS and Mail server settings to make sure they are correct.
If your mail server uses authentication you will need to turn this on and input a user name and password for your mail server. To turn on SMTP authentication you must enter service mode and change switch settings. I would recommend contacting a local Konica Minolta deal and have a technician do this. If you change the wrong switch setting you will cause all kinds of problems.
May 14, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub reads "server disk full": how to unfill server disk? or how to fix?
CAUSE: Machine memory is corrupt and the max out time needs to be increased.
SOLUTION: Perform a Data Clear:
1. Enter the Tech Rep mode.
2. Press System 1.
3. Press Initialization.
4. Press Data Clear.
Also browse to the NIC, enter Admin mode and set the connection timeout for E-mail to 300 seconds.
Apr 23, 2010 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta Bizhub c203 printer will print from all computers in our network, but has stopped scanning
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
Apr 05, 2010 | Konica Minolta Bizhub c203 Copier
Unable to scan to email after switch to Exchange 2007
check the server settings, maybe user authentication is needed, check from server side, what the printer is trying to do and where it fails. check printer e-mail settings, try these setting in computer.
Oct 05, 2009 | Konica Minolta bizhub C250 All-In-One...
MACHINE REFUSES TO SCAN SHOWING ERROR EA3229 ON BIZHUB 200 COPIER
As with most communications errors the first thing to always try first is shutting off the copier, unplugging it from the power source for at least 30 seconds, then plugging it back in, powering up and trying the scan-to-email functions again (once network synchronization has been completed by the copier).
EAXXXX is a communication's failure code generated by the copier to state that 1. The LAN cable is not physically connected, 2. Communication with the SMTP server has been lost, or 3. One or more of the e-mail addresses that someone attempted to send mail to doesn't exist or is invalid.
If the scan-to-email functions worked before this and have suddenly stopped, you may want to have your IT department reset the mail server.
It's also possible to have had some changes made to internal network address that has affected the copier's ability to communicate with the servers. Check with your IT to see if they've added any security software, changed network address structures, etc., around the time that the scan functions failed.
Aug 28, 2009 | Konica Minolta bizhub 200 Printer
Jul 31, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 - can't network scanner
Unless you are scanning to e-mail in which case you will need to put in the SMTP mail server settings into the admin section of your network settings.
Mar 07, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Scanning Problems
mail server issue. check your outgoing mail server. Most smtp depends on your isp. for instance, use smtp.sbcglobal.net for at&t isp. if you have an exchange server use your exchange server's outgoing mail.
Hope this helps!
chris
www.willhelpu.com
Jan 22, 2008 | Konica Minolta Bizhub-200 Minolta Printer
Can not make bizhub c252 scanning trough e-mail feature
with scan to Email on this machine you need a mail server that is local with ftp scanning you need IIS running on either XP Pro or server OS SMB Scanning can be done but only if you are using an eithernet connection which one of these do you want do to do
Sep 20, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub C364 Color Copier / Printer / Scanner Logo
123 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
