Question about Kitchen Appliances - Others
Trash compactor foot pedal won't stay up - Kitchen Appliances - Others
SOURCE: GE Profile trash compactor is stuck
This has happened a couple times to me and the fix is fairly simple. The problem is the trash ram is pushing down on the edge of the metal of the trash compartment because the door is partially open. The solution is to back-up the ram the the door will close.
To back-up the ram, you will need to pull the compactor out from under your cabinets and unplug it. Turn the compactor on it's side to expose the bottom. There is a plate on the bottom that covers the motor gears. Remove the plate and turn the large gear counter-clockwise to back-up the ram screws (at least this is how it works on my model works). The gears are a little greasy so you may need to add some after messing with the gears.
Good luck.
Posted on Dec 25, 2008
SOURCE: Trash Compactor Model GCG1500LOBB. the foot
I also found that after 2 years my GE Profile Trash Compactor (purchased in June '07), the pedal was hanging down on the left side. I searched the internet and called GE to no avail.
After a few attempts, I finally solved the problem by removing the screw on the left side and adding a metal "L" bracket, with the bottom of the L flush against the back of the front panel. That way, when you depress the pedal, the screw can't pop out of the metal it's attached to.
Dannys00
Posted on Dec 25, 2009
burdfrenzy
  • 348 Answers
SOURCE: I have a GE trash compactor I have to hold up the
There is a spring that holds up the pedal. It is broken or has come apart. By the pedal in the up position it is a safety switch allowing the compactor to run. You may have to repair this or simply put a small block under the pedal of the unit to run.
I hope my suggestions helps and all the luck to you.
burdfrenzy
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Posted on Dec 23, 2010
jcameo7270
  • 675 Answers
SOURCE: Does 15" trash compactor need
If the current rating on the name plate is 15A or better, I would have it on it's own breaker
Posted on Dec 27, 2010
Daniel S
  • 4323 Answers
SOURCE: GCG1580LSS trash compactor when I
Hi
The hum sound means that the motor is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Feb 07, 2011
Ge compactor stops after just starting
the running cycle for this type of trash compactor is a max of about 30secs. The fuller the bag is the shorter the cycle. However, if this is not how yours is running try checking to see if there is any trash stuck between the ram and the basket. Or make sure that the foot peddle is still staying in the "up" position.
Feb 27, 2012 | GE Stainless Steel Built In Trash...
I have a GE trash compactor I have to hold up the foot pedal for it to work. When I let it go the compactor stops. thank you
burdfrenzy
Dec 23, 2010 | GE Profile GCG1580LSS 15" Built-In Trash...
Compactor will not operate. The foot lift switch will not work to turn compactor on. I don't know if the compactor is in the full up position or down because when we got home...our 21 year old daughter...
You probably need to replace the actuator switch, part #9871976. This is a piece of metal that is attached to the foot pedal and pushes in the start button when foot pedal is lifted. Mine has broken twice.
Nov 15, 2010 | KitchenAid Architect S Series II...
Dannys00
Dec 21, 2009 | GE Profile GCG1580LSS 15" Built-In Trash...
Our 1 1/2 year old trash compactor will not operate
You may have to get a voltmeter or multi-tester and test voltage from power supply. Check to see if fuse is good. Check wires to pedal and lastly, use capacitor tester and test all capacitors to see if there is a faulty one.
Aug 25, 2009 | General Electric Profile JGP945 30 in. Gas...
Door hard to open
The tracks that the door are on have to be cleaned and lubricated with WD40 or equivalent. This should solve your problem. Hope this helps
Nov 09, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Good luck.
Oct 21, 2008 | GE Profile GCG1580LSS 15" Built-In Trash...
Kitchen Appliances - Others Logo
83 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
