Klik clocks can't shut off a klik niteglo alarm clock
SOURCE: Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Posted on Jan 25, 2008
SOURCE: setting time and alarm clock for timex nature sounds clock
Hold the time set key in until the time flashes. Now let it go and use the tuning forward and back keys to set the time. I had the same problem because I continued to hold the timeSet button down while trying to adjust it. If you do, the forward/back keys have no effect.
Posted on Jan 08, 2009
SOURCE: operating instructions for timex t311t radio/alarm clock
You can acces a PDF file of the manual at the following site: http://timexaudio.com/media/uploads/product/files/T311IB57574_35.pdf
Posted on Mar 04, 2009
  • 814 Answers
SOURCE: emerson research alarm clock
Sorry it took so long to give you a reply to your question. The problem you are having the resetting the Clock's function is covered in the owners manual of the product. I am giving you a web link page, that will take you to the Emerson Customer Support main index page for owners manuals. Here you will be able to find your make and model of Clock/Radio. Just open the page and you will be able to make the adjustments by reading the instructions from the owner's manual.[http://www.emersonradio.com/owners] Copy this link and paste it into the address bar of your web browser. You will need a pdf reader and writer to read the manual and make a copy for your use. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 14, 2009
Ranglo
  • 1194 Answers
SOURCE: Manual for Emerson smartset alarm clock
As you haven't mentioned the model no. so I am giving you a link from where you can download the manual for your appropriate model.
Good luck....and have a nice day. Rating the solution is highly appreciated.
Posted on Mar 19, 2010
How do I turn the alarm on model 14AV201 onn clock completely off.
maybe reading your manual tells about the alarm function .
Mar 13, 2016 | Audio Players & Recorders
How can I shut off the alarm on an unidentified clock radio?
Barbra; Alarm clock shut off and snooze button are not the same thing, if you want alarm off, use the slide switch, slide switch to alarm off position.
How To Set TIME ALARM CLOCK of VINTAGE Old LLOYD J375 771A RADIO AM FM...
How To Turn Off The Alarm On The RCA Talking Clock
Jan 25, 2016 | Audio Players & Recorders
I have wound the clock up but it still does not work
Mechanical clocks need periodic servicing. After so many years, even a well treated clock will have internal oil congeal and cause the clock to not run. I suspect your clock needs to be cleaned and rejoined to run properly.
I operate a clock service and repair shop.
Kliks Clocks
Jan 07, 2014 | Audio Players & Recorders
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
I can't turn off either alarm on the timex T308S and it's driving me crazy. I downloaded he lame manual. It's all about how to turn on the alarms. The little amount of information I found on...
  • Hi, I can help.
  • As long as the alarm indicator is illuminated on the LCD screen the alarms will sound.
  • To get rid of the alarm indicator press the "enter" button on the top of your alarm clock. No more alarms at all.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for leaving FixYa.
Regards, Tony
Aug 24, 2011 | Timex (T307S) Clock Radio
Problem with launcher Pro and alarm clock. No way to turn it off or to put on snooze. I can't switch off my alarm clock or snooze. I have to turn off the phone completely to make it stop. I use...
I had the same problem the other morning. All I wanted to dowas go back to sleep, but the alarm would not shut off.
Here is how to fix it:
Go into the clock, then alarm clock and click the menu button, then settings. Go to Slide Button Behavior, which will give you threeoptions, choose none.
Now, when your alarm goes off there will be a pop up and you can either choosedismiss or snooze. Please don't forget to give thumbs up!!
Jul 13, 2011 | McNeil-PPC Android Apps
I have the smart alarm clock model number 4511. I can't remember how to change the time for the alarm. I have pressed everything.
Open the door on the bottom of the clock. There's a switch there that unlocks the time setting function. After you unlock it, you can use the < and > buttons on the top of the clock to move the time back or ahead. Use the "mode" button to select between time and alarm setting functions.
Jul 11, 2011 | Brookstone SmartSet Alarm Clock
How do I set the alarm so it will activate on weekdays. It only works for Saturday and Sunday. Thanks
Hello
Sure Alarm battery Back-Up System
This SmartSet® Clock Radio includes a Sure Alarm battery back-up circuit that can
wake you up even if the power is 'Off'at the selected wake up time. If your power
is 'Off'at the selected wake up time the clock display will be off and the radio will
not operate, but a separate mini-buzzer will turn 'On'automatically to wake you up,
even if you had selected the "Wake to Radio"option.
The Sure Alarm will sound for 30 seconds and then shut off automatically.
To stop the Sure Alarm buzzer immediately, press the RADIO ON/OFF button.
Pressing the SNOOZE button has no effect during Sure Alarm operation.
Note: In order to maximize the life of the built in lithium battery, please be sure
to set the ALARM 1 and ALARM 2 switches to the "OFF"position if the radio
will be disconnected from the AC outlet for more than a few hours. This will
prevent the Sure Alarm from turning 'On'unnecessarily.
1.) Depress and hold either the ALARM 1 or ALARM 2 setting button.
The display will change from the correct time
to the Alarm 1 or Alarm 2 wake up time.
2.) While holding the ALARM 1 or ALARM 2 setting button, depress either the
SET + or - button to move the display ahead or back to your desired wake up
time.
3.) When the desired wake up time appears on the display, release the SET + or
- buttons.
Note: Be sure that you have set the wake up time correctly by observing
the AM indicator. If the AM indicator is 'On'the wake up time is "AM". If the
AM indicator is 'Off', the wake up time is "PM".
4.) When the desired wake up time (AM or PM) appears on the display, release
the ALARM 1 or ALARM 2 setting buttons
Apr 20, 2011 | Emerson Smartset Clock Radio
Cannot shut the alarm function off all together.
Disable the alarm permanently 1. Press CANCEL button. 2. The WAKE indicator will be flashing. 3. Press WAKE MODE button within 3 sec- onds to deactivate the alarm function per- manently.
Mar 23, 2009 | GE 7-4837 Clock Radio
Open Questions:
 Grubhead
Grubhead
