Question about Movincool Classic Plus 26 Air Conditioner
Movincool classic plus flashes tank - Movincool Classic Plus 26 Air Conditioner
3 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: Can Movincool classic plus 26 AC set the air temperature at below 70 degree F?
aircons normally pull down to approx. 17 degree celcius.and heats to approx 30 degree celcius.  most of the time you need to simply clean the condenser properly and to make sure fans are in good order.
Posted on Oct 23, 2007
  • 415 Answers
SOURCE: do the thermistors go bad? How can I tell, the
Conversion Chart for 10k Thermistors
Posted on May 01, 2010
Office Pro 12 - fan sounds like its running but no air flow...?
see if the air intake is not blocked or the filter screen has not collected dust [as you said its being lying around for awhile]
Jul 29, 2009 | Movincool Office Pro 12 Air Conditioner
My air conditioner is leaking water
The air conditioner have water runs into the plastic container and when the container is full of water the weight will switch off the whole unit until you empty this container.
The tube that deliever the water into this plastic container blocked up with dirt that stop the water runs into the container and overfill the condenser drain pan that water runs all over the floor. Clean this condenser pan outlet and the connecting tube then you will be ok.
Jul 01, 2009 | Movincool Classic Plus 26 Air Conditioner
My movincool 36 won't work - Stuck in HP Fail
I had this problem just this week, to fix it:
To RESET press FAN HI/LO and COOL ON/OFF buttons simultaneously for 3 seconds, controller returns to normal operation.
You can go to the movincool website and register for free. They have manuals and other things you may need.
Jun 30, 2009 | Movincool Office Pro 36 Portable Air...
IPOD CLASSIC FLASHING APPLE LOGO AND WILL NOT CHARGE PLUS WILL NOT RESPOND TO ANY COMAND IN FACT I CAN NOT DO ANYTHING WITH IT.
The flashing Apple is the equivalent of Microsofts blue screen of death. This apple symbol means hardware failure. Not good. Do a Google search for flashing apple of death. Here's a video that should help you fix it yourself. Hope this helped.
http://cnettv.cnet.com/2001-1_53-25928.html
Jan 04, 2009 | Apple iPod classic MP3 Player
Damaged stickers
Usually the stickers on the gas tank are under a clear coat of paint to prevent fuel spills from damaging them if so you will have to sand off the clear coat remove stickers replace stickers and repaint the tank. Im not familiar with your particular bike but you should be able to order new original stickers thru your honda dealership unless its a classic. Make sure you can buy the stickers and have a painter before you do anything.,,,
Nov 10, 2008 | 2006 Hero Honda Passion Plus
Fuel gage
Classic symptom of a failing sending unit. It's inside the tank and on most cars it's replaceable separate from the fuel pump. I usually see them in the $45-75 range. Some cars have an access panel under the rear seat or in the trunk, where others require the fuel tank to be dropped - I'm not sure offhand which your car requires, however.
Sep 29, 2008 | 2002 Oldsmobile Intrigue
GFI plug trips when pluged in, no reset
You are trying to draw too much power from the dedicated electrical line, or you may have an outlet that is needing replaced. Try to use another plug, in another room to test
Jul 21, 2008 | Movincool Office Pro 24 Air Conditioner
Oct 16, 2007 | Movincool Classic Plus 26 Air Conditioner
Movincool Classic Plus 26 Air Conditioner Logo
Top Movincool Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Movincool Heating and Cooling Expert? Answer questions, earn points and help others
