Question about Dryers
LGR4634PQ0/whirlpool gas dryer
All works but no heat. Why?
VOTIT
  • 2071 Answers
SOURCE: Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
Posted on Jan 28, 2009
  • 23 Answers
SOURCE: Gas dryer gets hot for a few minutes then goes cold.
Sounds like you need to replace the coils on the gas valve. Just make sure your venting is clear 1st. If it is, the coils are easy to replace. Remove the front panel and the coils are on the bottom right hand side. Two screws and the bracket for both comes off. One has two terminals and the other has three. Real easy once you get into the dryer.
Posted on Jun 19, 2009
Illeagle
  • 525 Answers
SOURCE: gas dryer-no heat. whirlpool lgr4634eq3. can i
Advise your landlord of the issue and follow his/her instructions.
I have provided some information on trouble shooting the dryer No Heat issue.
Below is a checklist provided by; www.repairclinic.com.
They also provide repair parts, disassembly procedures and diagrams for DIY repairs.
Firstly, ascertain that you have made a positive heat selection, then read on.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 12, 2009
hiltonjug
  • 612 Answers
SOURCE: Whirlpool Gold LGV4634JQ Gas Dryer Heating problem
Replace the thermostats. they are round pieces with a oval base. They have 2 wires, sometimes 3 going to them. They can be checked but it's kinda complacated.Although if you would like me to walk you through it I would be gale to if you will get back with me.
Please rate solution if helpful
Posted on Aug 25, 2009
SOURCE: whirlpool gas dryer no heat
One the terminals on the flame sensor fell off. II guess this is a common problem. relaced the sensor and
I'm back to drying clothes.
Posted on Oct 05, 2009
Whirlpool duet electric dryer turns on but doesn't
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 01, 2011 | Whirlpool Dryers
Heating unit on whirlpool dryer not working
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 23, 2011 | Whirlpool Dryers
Whirlpool gas dryer lgr7646dq1 is working but will not heat
heatman101
Nov 20, 2010 | Whirlpool GGW9200L Gas Dryer
I have a whirlpool GGN2000HQ0 gas dryer. Everything appears to work properly but there is no heat?
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 02, 2010 | Whirlpool LER4634J Electric Dryer
Our whirlpool dryer has no heat. Is there a
heatman101
May 28, 2010 | Whirlpool LEQ9858P Electric Dryer
Whirlpool Craetions Dryer AWZ129: No Heat
heatman101
May 15, 2010 | Whirlpool LER5636P Electric Dryer
LGR8648P0 does not get heat - Whirlpool gas dryer
heatman101
Mar 08, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer runs but no heat in it LGR4634PQ0
Check the simple things first - is the lint screen/trap clean? Is the exhaust hose free of obstructions? Can you feel air blowing out of the dryer exhaust when it is running?
If you answer yes to all of the above, you need to check the heating element. I would download a schematic from the Whirlpool website so you can check for continuity of the element and to see if you are getting power to the element. You will need to remove some covers from the dryer to make these tests.
Jan 11, 2010 | Whirlpool Dryers
Jun 15, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer no heat but runs
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE:
May 15, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
