Question about Home
RainSoft "Q2" brine tank has overflowed. Not draining. How to drain but don't want to waste brined water.
2 Suggested Answers
  • 11 Answers
SOURCE: Have an rainsoft Q10 classic apollo softner that
You most likely have a slight leak in the brine line. This is the most common failure on a water softener. A slight leak will allow air to enter during brine draw, breaking the vacuum. it doesn't take much of leak, in fact it can be small enough that water does not leak out during brine refill but it will not draw brine. Check the compression fittings at the brine tank and the softener valve. disassemble the connection, cut back the tubing and reconnect. Other things to look for are low water pressure, the unit requires 25 psi minimum during regeneration. Also make sure the drain line is not restricted and the maximum head on the drain is 4' over the softener.
Posted on Mar 23, 2010
Why does brine tank fill with water and overflows?
It sounds like there is a problem with either the valve in the head not sending water to the venturi jet when it is supposed to recycle or, the venturi or jet have an obstruction that is preventing it from creating the vacuum necessary to draw the brine back from the tank into the resin bed.
If there is water flowing out of the drain line during the recycle it is probably the venturi or jet need cleaning. If no water is flowing it is probably the valve assembly.
Nov 28, 2014 | Plumbing
Is there a city code for water softener recharge drain?
Well a lot of Cities and counties have there own ordinances for this. A good rule of thumb is not to discharge brine into sewer system or septic tank. Most drain into the yard. I have seen studies on different plants that actually thrive from brine water from softners. You may want to ant some of these and discharge that way. But to cover your self legally contact the City.
Jul 23, 2014 | Water Dispensing & Filtration
Waterboss 93000 water softener
It most likely is due to a plugged eductor/injector assembly which pulls the salt brine out of the tank to regenerate softener. If it is plugged no brine will be pulled from salt tank during regen but it will keep filling the salt tank and eventually overflow with each cycle. Or there could be a leak in the valve causing the tank to overflow.
Here is the owners manual for your model.
http://www.waterboss.com/media/WB_Softener_V1_Manual.pdf
See page 23
RJ
May 05, 2014 | Water Dispensing & Filtration
Water Softener full of water, not draining, or using salt
How old is the system ? Where does the system drain to ? If this is the softener you have (seems awful large for a household) it is probably the injector/nozzle assembly. I have attached a manual to help you. A restriction in the drain line could also be the problem. Fleck 2850s
Mar 20, 2014 | Fleck 165,000 Grain Series 2850 Commercial...
Softener not filtering water through the salt and not draining water from tank
What model of water softener do you have ? The one you have on here is for a chemical, not a water softener. Usually it is the brine injector or commonly called the nozzle/venture that gets clogged and will not create a vacuum to draw out the brine water. If you can put a picture of your water softener on here. I'd be more than happy to help you out.
Mar 20, 2014 | Seachem Discus Buffer 4 Kilogram Softens...
Harveys water softener leaking
Actually it is regenerating if it is filling the salt tank with water. It is just not drawing out the water/brine during the brining cycle. Check the eductor assembly it is most likely plugged with iron or debris. Clean thoroughly and manually cycle unit to brine draw. Usually second cycle, until the water level is back to normal then do a manual regeneration from beginning. Then regen 3 consecutive days.
Feb 05, 2014 | Reliance Water Dispensing & Filtration
It looks that water is leaking from the - Culligan water softner
Look down the tube (where the float assembly is) there should only be about 10-12" of water in there. For water to reach the brine tank over flow the tank would have to be 3/4 of water. Brine tanks can develop leaks over time if they were set on uneven ground or if any rocks or debris are under it. If there is no evidence of water running down the side of the brine tank this is the most likely cause. Also if it has been leaking for some time there will salt buildup around the brine tank. Check the water softener for any leaks also. At times a small leak from the softener will find it's way over to the brine tank and collect around the bottom of it.
RJ
Jun 14, 2010 | Culligan Sediment Water Filter
Have an rainsoft Q10 classic apollo softner that does not draw brine. Ran a wire thru the brine injecter tube and it appeared to be clear of obstruction. Drained tri-guard glass did startcycle and redrew...
Mar 16, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Kinetico Water Softening Unit has brine tank drainage problem
This sounds like the resin cylinder is perforated or connections at the top are leaking. The brine tank should only have a little water in the bottom - if it is full of water (maybe even up to the overflow?) then you will need to replace the resin cylinder or fix a leaky connection to it.
Is the water in the brine tank 'rusty'?
Feb 11, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Brine tank does not fill
If the brine tank is not refilling with water this indicates there is a restriction in the brine refill assembly or the refill piston is bad. Depending on the model this restriction could be either in the top of the float assembly or in the brine refill itself.
RJ
Nov 15, 2009 | Culligan Sediment Water Filter
Home Logo
69 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
