Question about Radio Communications
Skech bth561 headset flashes red and blue continuously
How do I get my skech bth561 headset to stop flashing red and blue light and beeping continuously ?
Peter Denton
  • 16 Answers
SOURCE: plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Posted on Nov 05, 2008
  • 7 Answers
SOURCE: pairing the insignia bluetooth wireless headset with an ipod
Perhaps either its pairing log is full, thay hold a number of pairing internally, and may need to be cleared to make room for another....or the headset may need to be reset, either way...heres the scoop....to clear the pairings hold the track forward/track backward buttons down together until the light flashes Purple....Empty pairing log......
If not then try pluging in the set to the charger and holing the 2 volume buttons down the same way..this will shut it off and reset it if it went a bit screwy on ya.... Merry Christmas
Posted on Dec 25, 2008
SOURCE: Bluetooth is flashing red and blue
sounds like your in pairing mode ... use your phone to search for the device ... when its found the system will ask you for a code ... enter "0000"
Posted on Jan 08, 2009
  • 32 Answers
SOURCE: headset does not flash red/blue so I can pair it with my phone
To get it into pairing mode (flashing red and blue) turn the headset off.  Hold the main button down until the light goes red and then off.  Then push and hold that same button and keep holding it even after the blue light comes on.  It will now go into pairing mode, flashing red and blue.  Set your cell phone to find it and it should work.
Posted on May 22, 2009
  • 4 Answers
SOURCE: No Sound or lights on the docking bay of the headset...
Hi Scott, have you tried disconnecting the power to the base with no headset, then power back on the base and reset the headset all lights on the base should light up to pair the unit, if the on light doesn't work after doing this process i would replace the battery in the headset, GN Netcom are shipping out new battery FREE for the GN 9120 a recall default. go to there web site for more details. Good luck
Posted on May 28, 2009
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Headlight blue light is flashing and won't do anything else
If you hold down the power button (and keep holding!) while wearing the headphones, you will hear three beeps (keep holding! If you lift your finger, you have wait a moment to start over) followed after a moment by two beeps. If you do this while the headset is NOT on, it will enter the "discoverable" mode and the lights should flash red/blue red/blue. If you do this while the headset is on, the second set of beeps sounds a little different, and those tones mean the headset is turning off.
The "manual" (a single sheet of paper) for this device is a joke, and website technical support is nonexistent.
When I first purchased mine, despite the poor instructions, I was satisfied, due to the low price. But I've only had the device for less than a month, and I've only used it three times, and suddenly I can't get it to pair with my laptop or my phone, though it had worked find a couple of weeks ago, last time I used it.
Sometimes you get what you pay for, I guess. Disappointing.
Dec 08, 2012 | Inland ProHT Bluetooth Headset Red
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Oct 31, 2012 | Audio Players & Recorders
Blue parrot lights blue and red keep flashing and there aren't any beeping noises
If your headset is 6 or more months old, it could be the rechargeable battery is due for replacement. The power supply or battery is the one thing that can cause all sorts of odd symptoms. I read your post and put a known bad battery into one of my 3 Blueparrott B250-xt headsets and did just as you described. If you would like to order a new battery for this headset, email me at ebhammonds@gmail.com. They are $20 and shipping is free.
Jan 02, 2012 | Radio Communications
When trying to pair my plantronics voyager 50 to my iphone, i am attempting to get the blue and red light to flash by pushing the up volume and the call button. but no flashes occur, even after 60 seconds...
  1. Turn on Bluetooth within your phone. Put phone into pairing mode.Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
  2. Pick the headset for Plantronics when prompted. Enter "0000" (four zeros)
  3. you should now have a continuous blue light blinking.
  4. Choose "Yes" if your phones asks if you want to bond to the Voyager 510 bluetooth headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics 510 Voyager Headset - PLN-510...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
I Can`t switch my headset on, and it stops charging after 20 secs
Move the call control button up or down, the indicator light will flash blue if it's paired or blue and red. If it flashes blue and red you need to pair phone with the headset. the passkey is 0000.
Jun 17, 2009 | Plantronics Explorer 340 Wireless Headset
I have a plantronics 520,
Start with your headset turned off. Press the talk button on the headset. Hold it until you see the light on the headset begin to rapidly blink red, blue, red, blue, red, blue, etc. Let go, the light should continue to blink red and blue. Go into your phones blue tooth menu and search for the headset. The phone will only find the headset if the headset is in pairing mode (blinking red and blue). The pass key is 0000.
Apr 10, 2009 | Plantronics Hama Voyager 520 Bluetooth...
Plantronics 520 will not pair
"Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue."
Dec 04, 2008 | Plantronics - Bluetooth Headset Plus Base...
Radio Communications Logo
144 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
