Question about Home
Rainsoft Q2 water conditioning system. Brine tank has filled & over-flowed. I have closed water going in& out of unit. What can I do to not waste brined water & get water out of brine tank?
2 Suggested Answers
  • 569 Answers
SOURCE: Kinetico Water Softening Unit has brine tank drainage problem
This sounds like the resin cylinder is perforated or connections at the top are leaking. The brine tank should only have a little water in the bottom - if it is full of water (maybe even up to the overflow?) then you will need to replace the resin cylinder or fix a leaky connection to it.
Is the water in the brine tank 'rusty'?
Posted on Feb 21, 2010
Testimonial: "Thank you so much. My husband is quite handy but never having dealt with water softener we were looking for some advice. We certainly appreciate it!"
Why does brine tank fill with water and overflows?
It sounds like there is a problem with either the valve in the head not sending water to the venturi jet when it is supposed to recycle or, the venturi or jet have an obstruction that is preventing it from creating the vacuum necessary to draw the brine back from the tank into the resin bed.
If there is water flowing out of the drain line during the recycle it is probably the venturi or jet need cleaning. If no water is flowing it is probably the valve assembly.
Nov 28, 2014 | Plumbing
Cloudy/salty water, stuck bypass valve
water in your salt store is normall. it is commonly called brine. this is purely a cleaning agent of your water softener to regenerate the media. you do not drink this water nor does your water pass through this. it is only pulled through into the unit when regenerating.ie. this piston is in a position which allows the water to flow through a v enturie pulling the salt. water will sit in the brine tank always to be ready for the next generation and to be at the correct brine dilution so it's important to maintain the salt level above the water level. cloudy water is nirmally air bubbles which should settle out within a couple of minutes . if it tastes salty I suspect your regeneration waste water is contaminating your supply feed. like seeping back into well or tank .
Apr 18, 2017 | Water Dispensing & Filtration
Water softener fills up with water
If you are referring to the salt tank filling with water, then the problem is the eductor assembly. This is where the brine is drawn from the salt tank. If it is plugged no brine or very little brine will be drawn during regeneration. You will need to clean the eductor assembly and manually regenerate the softener to regain softened water.
What model softener is it? It would help to bail most of the water out of the salt tank. How much depends on the model.
RJH2O
Jan 26, 2013 | Measuring Tools & Sensors
Water level after regen is over half the way up the brine tank
The eductor assembly is plugged. This will cause the unit to not draw brine but will keep re-filling salt tank causing high water in tank.
Take the cover off the control. On the left side of control there is small dome shaped apparatus. The"eductor assembly" is inside here. By-pass the softener, run it through a quick regeneration (to depressurize the system) Hold the regen button down until it starts through cycle, then push regen to cycle through each step of regen until it goes back to service. You will see this (S) on top of the valve where the main drive gear is.
When depressurized, take the lid off the eductor housing, disassemble and clean all the small holes completely. Be cautious of small nozzles and small screen in system as they can be easily lost.
Re-assemble, put water back to unit. Run through manual cycle again.
1. Refill
2. Backwash
3. Brine draw
4. Rinse
Then advance to backwash and let system go through complete regeneration.
You will have to bail most of the water out of salt tank as it will never draw it back down to proper level with that much water in tank. About 4" of water.
RJ
Jul 28, 2011 | General Electric Company 45000 Grain Water...
My softener sucked all the brine out of the brine tank the last time it regenerated, now it will not fill back up?
It is not going into brine refill. There may be a restriction (debris) at the float assembly in brine tank. or the refill piston in valve may be bad.
H2OServices
Dec 26, 2010 | Culligan Under Sink Water Filter
I have a Kenmore Refrigerator: Model Number 106.50254001, Purchased 1-24-2001. It has a water and ice dispenser on the front. I purchased a Rainsoft Water Softening system, with a Reverse Osmosis System...
The water pump probaply is switch on by a flow switch. So the solution is to install a pressure tank after pump so to have stable pressure and not a pulsing one.
Sep 27, 2010 | Kenmore Refrigerators
It looks that water is leaking from the - Culligan water softner
Look down the tube (where the float assembly is) there should only be about 10-12" of water in there. For water to reach the brine tank over flow the tank would have to be 3/4 of water. Brine tanks can develop leaks over time if they were set on uneven ground or if any rocks or debris are under it. If there is no evidence of water running down the side of the brine tank this is the most likely cause. Also if it has been leaking for some time there will salt buildup around the brine tank. Check the water softener for any leaks also. At times a small leak from the softener will find it's way over to the brine tank and collect around the bottom of it.
RJ
Jun 14, 2010 | Culligan Sediment Water Filter
Have an rainsoft Q10 classic apollo softner that does not draw brine. Ran a wire thru the brine injecter tube and it appeared to be clear of obstruction. Drained tri-guard glass did startcycle and redrew...
You most likely have a slight leak in the brine line. This is the most common failure on a water softener. A slight leak will allow air to enter during brine draw, breaking the vacuum. it doesn't take much of leak, in fact it can be small enough that water does not leak out during brine refill but it will not draw brine. Check the compression fittings at the brine tank and the softener valve. disassemble the connection, cut back the tubing and reconnect. Other things to look for are low water pressure, the unit requires 25 psi minimum during regeneration. Also make sure the drain line is not restricted and the maximum head on the drain is 4' over the softener.
Mar 16, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Feb 11, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Water softner problem, does not refill water to brine tank
There is .25 gpm flow restrictor in the top of the float assembly, It may have sediment in it. Unscrew the cap on float top and check the restrictor. When you hook it back up run the system to refill (last cycle) hold the float stem down until all the air is purged from float assembly and see if that works. Also the float ball (foam) may have slipped top too far and is shutting off prematurely. If this does not work it is in the valve which has small pistons, diaphrams and springs to control the cycles. Each cycle also has a solenoid which makes these components work. You will not find a service manual for the Mark 50 valves. They are obsolete unfortunately and parts are no longer available. This valve was made for nearly 40 years and was the hallmark of the Culligan line.
RJ
Jan 03, 2010 | Culligan Sediment Water Filter Heavy Duty
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
