Question about Heartthrob Exhaust 2002 Chevy Silverado - 2500HD, crew cab, short bed, 6.0L V8 - Cat-Back Exhaust System
2002 chevy silverado ac low pressure port.can i replace the valve inside
Can I replace valve inside port and if so how do I without letting all the Freon out?
Where is the low port located in the engine to recharge the ac for a 2008 Chevy Malibu LTZ 3.6 v6
The low pressure side to the ac will be the Schrader valve that is the smallest size. If you are recharging it yourself try to fit you valve on both valve and you will see what I am talking about.
May 04, 2015 | AC Cars & Trucks
Can't locate the suction port on AC system. 2002 Chevy avalanche
Follow the larger diameter pipe below your high pressure valve, between that point and the compressor
Mar 16, 2013 | Cars & Trucks
Where is the a.c. low pressure valve for 1988 chevy silverado 2500?
FOLLOW AC COMPRESSOR SUCTION LINE FROM THE RECEIVER DRIER OR ACCUMULATOR TO EVAPORATOR IN THE FIREWALL. YOUR LOW PRESSURE PORT EITHER ON RECEIVER DRIER OR LOOK FOR SMALL EVAPORATOR LINE WITH BLUE CAP GOING INTO FIREWALL TO THE EVAPORATOR.
Jul 27, 2011 | 1988 Chevrolet Silverado 2500
2004 chevy blazer ac stoped working and if the ac is turned on it stoped the engine abruptly, the pressure on the low pressure port without the engine on reads high at 150psi which is the red danger zone...
I would suspect you have a bad A/C compressor. When you engage the A/C, the clutch locks up the pulley which kills your motor from the drag on the belt. Replace the compressor, evaporator and valve, then recharge system to 55 psi.
Jun 11, 2011 | 2004 Chevrolet Blazer
Where is the low pressure ac port for a 2002 C230 Kompressor Mercedes Benz?
open engine hood its at the right front on the ac condenser it's covered by black plastic flap open the little flap you can see the low pressure valve in it.
Sep 25, 2010 | 2002 Mercedes-Benz C-Class
Where is the low pressure ac port or valve located at? on a 2002 mercury salbe
The low pressure ac port on my 2001 sable is located by the passenger side firewall.
Jun 29, 2010 | 2002 Mercury Sable
Where is the low pressure port located on a 2002 chevy impala?
My 200 impala with 3.8L.... the low port is located on the firewall need the red transmission dipstick.
see picture at: http://s2.photobucket.com/albums/y48/ZeeVert/2002%20Impala/ac%20condensor/?action=view&current=P1190272.jpg
May 21, 2010 | 2002 Chevrolet Impala
Need to know how to replace refrigerant pressure sensor on 2003 Chevy Silverado 1500 air conditioner compressor.
The low pressure switch screws into the side of the accumulator and it should have a shrader valve so you can replace it without loosing all of your refrigerant.
Apr 19, 2010 | Chevrolet 1500 Cars & Trucks
AC Low Pressure location on 2004 Chevy Suburban
You find the AC low pressure at the top of the compressor, orientated toward you , facing the front of the vehicle. You can also follow the compressor line to reach the port.
The valve is covered a plastic cap covering it.
Near the compressor you find two ports, the high port and low port.
To find out which one is the low port, run the air conditioner for a couple of minutes withthe engine on.
Then turn off the care and touch the lines from compressor to the two ports covered with plastic caps. Only one of the pipes will be cold, the cold line will lead you to the low port.
Regards.
Jun 18, 2009 | 2004 Chevrolet Suburban
WHERE IS THIS PORT LOCATED?
You have to take off the Front Grill pop the plastic holders on top then pull very hard. It will come off. let me know if that fixes it i went to recharge mine and it was completely full. They said i had a clogged condenser.
May 20, 2009 | 2002 Suzuki XL-7
Heartthrob Exhaust 2002 Chevy Silverado - 2500HD, crew cab, short bed, 6.0L V8 - Cat-Back Exhaust System Logo
64 people viewed this question
Top Heartthrob Exhaust Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Heartthrob Exhaust Wine and Spirit Expert? Answer questions, earn points and help others
