Question about Stihl Bg 55
When I pull start my stihl 55 leaf blower gas comes out exhaust port what is causing this
Gas comes out exhaust port when I try to pull start stihl 55 leaf blower what is causing this blower will not start/
5 Suggested Answers
  • 2239 Answers
SOURCE: Stihl Leaf Blower no top speed model BG86C
If there is a spark arrester in the muffler outlet check this is not blocked with carbon.
Posted on Jun 10, 2012
  • 6468 Answers
SOURCE: Stihl Leaf Blower BG86c no top speed
take off the muffler and run it the screen inside it might be plugged and you can clean it off by opening the muffler
Posted on Jun 13, 2012
  • 430 Answers
SOURCE: STIHL BG75 LEAF BLOWER ELEC. SYSTEM
The unit uses a magneto system. To test the module remove the black wire from the module then reassemble unit and test for spark ( spinning by hand will not work, you need to use the starter rope to get the needed RPM to create a spark). If you have no spark with the ground wire disconnected the module is bad and needs to be replaced. If you DO have spark with the ground wire disconnected then you have a pinched wire going to ground or a bad stop switch
Posted on Oct 15, 2012
plink_plonk
  • 1807 Answers
SOURCE: schematics for a Stihl backpack leaf blower model # BR550
http://www.h-machine.jp/part_list/stihl/stihl_BR%20500,%20BR%20550,%20BR%20600.pdf
Sorry its in Japanese but the part numbers are the same. :)
Posted on Apr 03, 2013
I have a BG55 blower when I try to prime it no gas come in bubble. I have made sure there nothing in gas line,and it skeet when I put a pin in the little hole, but no gas when u try to prime.
Apart from the bubble there is at least one non-return valve that could be stuck or not working because it is dry.
Could be removing the bubble and wetting everything thoroughly with fuel and quickly refitting it could kick-start it and make it work.
Sep 05, 2016 | Stihl Bg 55
How do I fix my Poulan Pro bvm200fe?
If you do indeed have (good)fuel and spark to cylinder, I suggest you remove muffler and clean the internal screen/mesh and carefully scrape off carbon around exhaust port. Do not let debris fall inside engine when cleaning.
Repairing my STIHL FS 38 Clogged Muffler Fix
How To Troubleshoot Your Weedeater to crank every time
Feb 20, 2016 | Poulan Pro 25cc 2-Cycle Gas Blower...
Will start with chock on but wont stay running with it off
the idle jet or the float valve is blocked
you need to strip the carb and unscrew the jets and clean them
i use small interdental brushes ...
Mar 23, 2014 | Stihl Blower Handle Moulding Bg Sh 45 55...
I can't get my blower to accelerate. It will only idol on full choke. If you pull trigger it bogs down. I replaced the fuel line and sprayed carb out.
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the Fuel Tank
  • Spark Plug
  • Spark Arrestor - at muffler
  • Carburetor - May need a rebuild kit
Watch this as well...
and...
Oct 18, 2013 | Stihl Bg 55
Blower bogs down and kills at full throttle
Check the following, then clean or replace:
  • Fuel Filter - Located IN the fuel tank
  • Spark Plug
  • Spark Arrestor - at muffler port, creates resistance of exhaust flow, engine then bogs
  • Carburetor - may need a rebuild kit
Then watch this...
and...
Mar 31, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
The Stihl 46C will not accelerate and cable and gas is good. Help
Check the spark arrestor, or the exhaust port are not blocked with carbon.
Sep 13, 2012 | Stihl Bg Sh 46 46c 85 85c Blower,...
Homelite gas leaf blower losing power
There might be a small screen in the exhaust (it's a spark arrestor) that gets plugged with carbon. Will cause loss of power and eventually the machine will not run. You can just take the screen out and it will run better. Check the exhaust ports (look into the cylinder area after you take off the muffler) and see if it/they are plugged. If so, use only plastic or wooden items to clear the carbon out. Be careful not to get any in the cylinder. If you do, pull the starter rope several times to blow out the carbon.
Otherwise, some fuel line cleaner would be a good try to assist in the problem.
Dec 28, 2009 | Homelite 'Yard Broom' Leaf Blower
Need to know the gas to oil mixture for a stihl bg 55 leaf blower,
2oz oil / 1gal gas is a good rich mix. you can go up to 2oz oil / 1 1/4 gal. gas. Use only good quality oil.
Nov 07, 2009 | Garden
Stihl Bg 55 Logo
44 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
