Question about RCA F38310 38" TV
Mitsubishi 1080 72in diamond seris
Tv cycles through the vid 1 vid2 ant a ant b...then the volume controls pegs to max....removed remote batteries n problem still occurs...what can i do?
52" mitsubishi 1080p t.v. warning shows up on screen AIR FLOW IS BLOCKED. Check owners guide and they don't tell you how to clean it or where it si at.
Posted on Aug 29, 2007
I need a code for a blue diamond tv model number BD40DL fev10
Remote Code for Blue Diamond TV - > Talk to... > Sky Ireland
Aug 7, 2015 - After checking our database for remote codes we don't have a codeavailable for your particular make of TV, Blue Diamond. I will be sending ...
Horizon UPC Blue Diamond LED Remote Control - > ... > Cable & Digital TV > Cable & MMDS & IPTV
Dec 11, 2013 - I have bought a BLue Diamond TV and upgraded to UPC Horizon HD. ... the code for Mitsubishi who from what I can see make Blue Diamond Sky Remote COde
May 29, 2015
Anyone code for programming sky remote bluediamond tv?
Dec 10, 2012
More results from
Dec 10, 2015 | Televison & Video
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
Need to access service menu
GO to All TV Service Menu Code to browse olmost tv factory mode.
You can find lot of service code for tvs, DVDs, Monitor and many more.
Mar 27, 2011 | Toshiba 26AV52R LCD TV
Replacement Remote
Thanks for using FixYa. Yes Universal remote control can be used on Mitsubishi TV CS32307 for which you can place order on the following link---
Replacement Remote Control for Mitsubishi TV CS32307
Please do accept the solution if the issue is resolved or else revert for further assistance.
Jul 31, 2009 | Mitsubishi CS-32307 32" TV
Trying to hook up system to tv and can't get sound after doing so. what should i do?
output on tv to input on unit.. make sure the unit is in the proper mode that corresponds wher you hooked the wires into ex. aux. vid.1, vid2..
Jul 31, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose LS5 max volume!
you better replaced the volume control it is depected already with identical ratings so it works normal again.. Hope it may helps;;
Jun 08, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Tv wont respond because device menu is changing through each device
I had a similar problem: my WS-55511 would not respond to the remote and the front control buttons (with the exception of Power) cycled through the Device Menu. I solved this problem by disconnecting the front panel. Here's how to do it: 0. Unplug the TV
1. Remove the speaker grill from the front by pulling forward: there are no screws. 2. Disconnect the two cables that are exposed after the grill is removed. 3. Plug the TV back in, wait for 5 minutes to reset. 4. Try using the remote.  Hope this helps!
Oct 06, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Ant A and ant B
There should be 2 buttons labeled Input, in between Volume and Channel. Press up on Input. If you are using a remote different from the one that came with the TV, then look for a button labeled 'Input' 'Int' or 'Mode' somewhere along the top.
Mar 29, 2008 | Mitsubishi CS-35405 TV
Use the input button on your remote control... as you press input you should see VID 1, VID2, COMP 1, FRNT and then DVI... When you get to DVI you should see your picture..
Oct 15, 2007 | RCA P52926 52" Rear Projection Television
RCA F38310 38" TV Logo
57 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
