Question about Ranger Communications TR-127FS 40 Channel AM CB Radio TR-127FS
I need a manual for texas ranger tr-127fs
Swr meter not moving
I need a manual for texas ranger free spirit cb model tr127fs manual. Can you help me?
I would try using the manual for the TR 127GK or the DX models and see how they work out for you. I did a google search and came up with nothing.
Aug 14, 2014 | Radio Communications
Need user manual for a Ranger TR 127FS
Service manual is on the CBTricks.Com website. Look in the index for TR-127GK. This the same radio under the covers. This should suffice as an owners manual also.
....Don at NTCB, Inc.
Jun 22, 2011 | Ranger Communications RCI-6900F-25 CB...
Is it possible to convert the texas ranger tr-396fc from cb to 10 meter amateur band?
Note - You must have an Armature License to legally perform this conversion.
1. Remove bottom cover from radio. 2. On the main PCB, locate J33. (See diagram above) 3. Locate wires on pins marked "P5" (yellow) & "P6" (grey). 4. Cut wire on "P5" (yellow) and install a SPST switch in line. 5. Cut wire on "P6" (grey) and install a SPST switch in line. NOTE: By using two of the function switches available on the radio will eliminate the need for two new switches to be installed and mounted.
Mar 08, 2011 | Ranger Communications TR-396FC 40-Channels...
Texas ranger cb tr-396FC \r\nhello, do not hear anything in the speaker and do not find any scheme or service manual. Yours sincerely
Is the speaker the internal or external one ? disconnect the external speaker then take a multimeter on ohms with sound and touch the pos and neg contacts . you will hear a beep ,now look at the meter and read what ohm reading you have.check to make sure you are on band mode and not pa . If you hear nothing add an external speaker which will over ride the internal speaker and see if you still get nothing. Now that you have confirmed this you may want to take it to a tech and have them fix it. And I did a google search and found a service manual for this radio .
Dec 27, 2010 | Ranger Communications TR-396FC 40-Channels...
How to tune a galaxy 55v mobile to receive better
really the only thing you can do to the radio is make sure it is aligned, and that it is receiving on frequency. Although this unit has a frequency counter that will tell you where it's receiving, you cannot successfully put the radio on frequency unless you fully align the radio. In order to align a radio you need a volt meter, watt meter that reads avg watts, and an oscilloscope.
A volt meter and watt meter is easy to come by, however the oscilloscope is an expensive piece of equipment to attain.
You can just as easily tune your clarifier to the correct receiving frequency on the counter.
An easier way to improve your receive on any radio is to make sure the antenna is tuned for best SWR. When an antenna is tuned to the proper length for the best SWR your receive will get better because your antenna will be on Que.
There is also a Schottky diode upgrade that can be done. This consists of changing the detector diodes in the radio to schottky diodes as well as changing a transistor. This mod improves receive in most galaxy radio a great deal.
You can get these as a kit with full instructions on ebay fairly cheap.
You need to replace diodes D1, D2, D23, D24 with the schottky diodes in the kit, then replace TR-17, with the transistor that comes in the kit. Then remove TR-14. and them remove TR-19, and put the transistor from TR-14 in the TR-19 spot.
The Transitor that goes into TR-17 is a 2sc2999. I can't remeber what the Schottky part number is. But like I said, they sell the kits with complete instructions on ebay.
Here you will find all the technical information about your radio, as well as alignment guides.
Here is a link to ebay with an upgrade kit and instructions on ebay.
Oct 13, 2010 | Galaxy Radios DX-55V Base CB Radio
Hi i have a texas ranger 696f base and cant find any info on it to adjust my rf signal meter can you help m?
schematics and alignment procedures are widely available for this radio on the internet. a little research goes a long way.
p.s. if you don't know what you are doing leave it for a skilled tech. you could cause some major issues if you "allign" the wrong thing.
Jul 01, 2009 | Ranger TR-396F CB Radio
Audio limiter
tintlady, here is the info you requested;
the AM limiter is R 276
These are the variable adjustments inside,and what they control.
VR-1 AM S-METER
VR-2 SSB S-METER
VR-3 SSB SQUELCH RANGE
VR-4 AM SQUELCH RANGE
VR-6 SSB CARRIER BALANCE
VR-7 TX OFFSET
VR-9 RF METER
VR-10 FINAL BIAS
VR-12 DRIVER BIAS
VR-13 SSB ALC
VR-14 AM HIGH POWER
VR-15 AM MODULATION METER
VR-16 AM MODULATION
VR-17 SSB POWER
VR-18 AM LOW POWER
VC1-10.240 MHz Frequency adjustment
Hope this helps you out, let me know,,Mechanic
Jan 20, 2008 | Radio Communications
Ranger Communications TR-127FS 40 Channel AM CB Radio TR-127FS Logo
Top Ranger Communications Radio Communications Experts
AnyMHz.com
AnyMHz.com
cwradio73
Mike Charette
Are you a Ranger Communications Radio Communication Expert? Answer questions, earn points and help others
