Question about GE Dryers
Ge dryer dde7100 nbl
I have an older GE clothes dryer that keeps burning the wire that feeds the heating element where it attaches to the motor switch. unfortunately the wiring diagram on the back of the dryer is no longer readable. My local appliance parts store says the switch is no longer available so I need to buy a motor. I would like to make sure that the switch is the only problem before I replace the motor. For that I need a wiring diagram. Is there one available?
  • 58 Answers
SOURCE: motor centrifugal switch bad
You cant get the switch seperate for that motor, you have to get a whole new motor.
Posted on Oct 31, 2007
  • 19 Answers
SOURCE: how to get to heating element on ge dryer
Most heating elements can be accessed by removing the back cover of the dryer. Please unplufg the dryer first before starting this project.
Posted on Nov 09, 2007
hotuna
  • 288 Answers
SOURCE: Ge Commercial Coin-Op Dryer.
When you replaced the motor, did you replace the relay? It sounds like you have done everything reasonable. I would try bypassing the coin operation part and see if that changes anything. Go back to the motor relay. It may be incorrect application. the part guys only know what the computer tells them. it may need a different one. I am assuming that when the unit shuts off you checked for power from the timer to the next place, according to the diagram.
Posted on Mar 13, 2008
Testimonial: "Ended up selling all of our commercial washer/dryers and going with a rental company. Best all around for our cost, man hours and headaches."
kachbibi1
  • 979 Answers
SOURCE: Candy CMD146 Washer Dryer drum spins but does not heat
Yes it could be the heating element. However, it could be the thermal overload switch. This is located under the top of the machine. Bypass it to see if works. If it does, then it is the switch. If not, check the element. It sounds like this is the element with the 2 yellow wires.You will need to pull it to visually check to see if it is burned in 2.Check the element first since you have easier access to it. Let me know how this works.
Posted on Jan 28, 2009
dragonsthatk
  • 547 Answers
SOURCE: need schematic for replacement motor GE dryer model DDE6350GALWH
http://www.partstap.com/ please go here for diagram thank you please rate me
Posted on Feb 22, 2009
I have a older ge dryer and I'm having problems with it.The problem is that it heats up good sometimes and then want heat at all sometimes.Any suggestions that you may have?Help!!!!
It either a burn wire are the connection to motor is burn or broken are the. Heat element had bad connect,if you don't know-how to check dryer you may need call a service tech.
Feb 17, 2015 | GE Dryers
I HAVE A GE DRYER THE MOTOR SHUTS OFF WHEN YOU RELEASE THE START BUTTON AND THE DRUNM WONT ROTATE
there's a broken belt switch connected to the belt idler pulley,(when this belt breaks the switch opens) located down by the motor and it kills the power to the dryer when the belt breaks so the heating element cant get the clothes too hot to burn the clothes when the drum cannot rotate properly
Feb 25, 2012 | General Electric Dryers
MY OLD GE ELECTRIC DRYER TURNS ON BUT WILL NOT HEAT
Make sure you check these to fix the problem.
  • Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
  • Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
  • A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Thank you
Aug 02, 2010 | GE Profile Harmony DPGT750EC Electric...
GE Front loader doesn't dry clothes completely.
Hello there:
f yourdryer won't heat up, it's possible that it is not being supplied withthe proper voltage. Here are three ways to make sure power is gettingto your dryer: First, make sure your dryer is plugged in. Next, checkthe circuit breaker panel to make sure all the circuit breakers are inthe correct positions. Finally, check to make sure no fuses in yourfuse panel are blown. Any of these could explain why power is notgetting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 23, 2010 | GE DCVH515EF Electric Dryer
Dryer back over plug is too hot, smells like its burning, burns to touch, what's up? Just started, nothing unusual with the loads of clothes or anything...just when it heats up, it is way too hot...
Sorry to hear that. Your Dryer is now a fire hazard. Somehow it is using a lot of current (perhaps a faulty motor or the heat element have a short circuit). I do recommend you stop using the dryer immediately and request a technician to determine why the appliance is taking a lot of current.
I have seen a similar problem before, it was caused by a wire that came off from a bra and stuck in the heating element.
Don't wait for an accident just to save some bucks.
Good luck.
Sep 30, 2009 | GE DSXH43EAWW Electric Dryer
Holes in Clothes
You'll need a drill with a wire brush attachment and take that to the front of the heating element. The heating element gets a lot of crud built up on it and yes it'll put holes on clothes.
Apr 02, 2009 | GE DWSR405EBWW Electric Dryer
JUST CHANGED MY GE DRYER TO A 4 PRONG PLUG, NOW NO HEAT
Sounds like your heating element is burned out (acually burned threw) when you moved it if the element was weak it may have broke in two along the coil wires.
Happens alot.
Feb 17, 2009 | GE Dryers
Ge dryer not heating
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Heating element
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
Aug 15, 2008 | GE Profile Harmony DPGT750EC Electric...
New GE Dryer Not Heating
Heating element
Thermal fuse
Wiring
Jul 25, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
GE Profile Harmony Dryer DPGT750EC Drum won't turn & no heat
Heating element
Thermal fuse
Wiring
Jul 04, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
89 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
