Question about Dell Studio Xps 7100 Desktop Computer (AMD Athlon II X4 630 1500GB/8GB) (DXPDDY413)
I bought a second hard drive for my Dell Studio XPS 7100. I don't see where I can hook the second hard drive to the power cable. Do I need to buy a new power cable and if so where do I hook it up?
I see a power cable connected to the primary hard drive but don't see a spare power cable (which I thought was standard), and I can't see where a new power cable would go.
  • 9 Answers
SOURCE: My Dell will not start
If you any experience getting into the system bios you can check to see if the system still sees the hard drive by pressing the F2 or DEL key on startup. This screen shows a system bios with hard drives present. ( http://techgage.com/reviews/asus/barebone_690/pundit_21_thumb.jpg ). If it does not show up it could be that it came unplugged however unlikely. But you could try opening the system and checking to make sure the hard drive is still plugged in. Some manufactures tend to plug devices in fairly loosely. It may look something like this (http://www.laray.com/build/drive5.jpg) or like this (http://lib.store.yahoo.net/lib/cooldrives/ide-drive-to-sata-adapter-plug-image-2.jpg)
If all this seems too much, you could take the PC to a repair shop and have them check to see if your harddrive is still properly installed. If it is still installed but keeps giving that error then you probably need a new hard drive.
Posted on Dec 09, 2008
localwonder
  • 6784 Answers
SOURCE: Dell XPS 600 turns itself on to solid amber
Hi. the mother board seems to be having some initialization issues during boot up. this is common when the mother board is failing. i would check to make sure the battery on this board is working. if it is, the board my be ruined.
power board seems to be fine.
please rate and god bless.
Posted on Mar 17, 2009
Bat1956
  • 585 Answers
SOURCE: hello, I have a Dell
Was the original drive also a SATA? If not, then you would need to enter the bios setup and enable the onboard SATA channels. If the bios had gotten defaulted, as from a dead CMOS battery etc. it could have also caused your original SATA drive to be inaccessible.
Posted on Nov 25, 2009
  • 164 Answers
SOURCE: Dell: Primary hard drive 0 not found Primary
Sorry, but this isn't a good sign. Drive 0 is most likely your main hard drive, and only if you have a second one would you computer ever find anything on Drive 1.
I would check the connections inside from the motherboard to the hard drive, as well as from the power supply to the hard drive.
Here's the manual: http://support.dell.com/support/edocs/systems/opgx60/en/ug/sffabout.htm#1103481
Also, if you boot your computer to the Dell copy of Windows, go through the motions of reinstalling Windows and you probably won't be able to detect any drive to install it on.
You'll most likely need to replace the hard drive altogether. Sorry!
Hope this was helpful for you (even though it was bad news)! If so, please give a rating!
Posted on Mar 09, 2010
drifterK
  • 4924 Answers
SOURCE: Dell Studio 540 MT No connection from PC to
in this case it is probably the video card ...so ..if you have a on board one ...just move the cable to it..(its placed near the other on board plugs like usb and printer plug ) but you may need to remove the faulty card from the computer in order to let the on board one to work ...also try to see if it is not just a case of plugging the card better in the slot ..or so ...there can not be anything else cause if the monitor says there is no signal this is the only issue possible..if the computer starts ....
Posted on Jun 15, 2010
Replacing power source
IF YOU MEAN PSU STUDY HOW THE YOU REPLACING IS
MOUNTED AND CABELS LAYD.
Feb 14, 2014 | Dell Studio Xps 7100 Desktop Computer (AMD...
Dell studio XPS 7100 tower. the power light is orange and it wont start
The amber light can mean that the power supply isn't providing enough power to the system board or that the system board (or the CPU on the board) isn't working.
Since your fans are working, your power supply hasn't completely failed and the board is providing power to the system fans. Thus, either the power supply is giving limited power, your CPU has failed or the motherboard isn't talking to the CPU anymore. (The BIOS is only accessible when the CPU is operational.) I'd first try a new power supply. Make sure to get one that has at least the same power rating as the original, matches the wiring in your case and will fit in your case. (Note: you need to be careful. 1) Some Dell systems use a proprietary power supply (shape and wiring). 2) Many current power supplies are rated by their peak power output, not their stable power output. You want to match or exceed the stable power output of the current power supply.)
If the power supply doesn't solve the problem, I suggest getting a new computer is better than a new CPU or motherboard. (The Dell Studio XPS 7100 was released in 2010.) Replacing the CPU or the motherboard makes your computer a new machine to Microsoft and you may have trouble getting a working license. (You'd have to call Microsoft for activation and they probably will want to charge you for a new license.) Take your hard drive out of the current machine to get your data from it. You can put the drive inside another desktop with SATA ports, use an external drive enclosure (3.5") or SATA drive dock, or a USB to SATA drive adapter.
I hope this helps.
Dec 28, 2013 | Dell Studio Xps 7100 Desktop Computer (AMD...
My flopy drive will not read any disc I pu in it.
Floppy on an XPS? Is the drive an external one? What operating system?
Oct 14, 2013 | Dell Studio Xps 7100 PC Desktop
Don't know how to connect hard drive to motherboad?
find in motherboard sata 1,sata 2 or" fdd socket.
May 30, 2012 | Dell Xps 8300 Desktop Computer
I have a dell xps studio 7100 with a 500gb hdd. I want to buy a 2tb and make a secondary drive for storage on my media center. How do i install a second hdd for storing my video files and music?
installing the secondary harddisk may cause to slow the system as to install first change up the ram and then partations of hard disk may be done while formatting so u can store what ever accessarioes u need
Dec 13, 2010 | Dell Studio Xps 7100 PC Desktop
Received Dell XPS 8100. No cd player so they sent me one. Dell hell it is. Anyway, I opened it and found MANY wires unconnected. Can you tell me what connects where? I took the cd burner out of my old one...
Your old computer had IDE interface, the new computer has SATA interface.. There is a thin connector power cord and interface cords with tge same width connectors.The existing hard drive has thes cables connected to it. Connect one power cord and one data interface cable to the cd drive. Connect the audio cable to the cd drive and the Audio IN connector on the motherboard.
Unless the motherboard has a ide connector. you can not use your old hard drive or cd. You can get a external drive encloser that can convert IDE to USB
Oct 14, 2010 | Dell Studio Xps 8100 Desktop Computer
Hello, I have a Dell XPS 400 system that has a bad hard drive. So I went out and bought a new SATA drive, and it's not detecting it upon boot. When I go to the boot menu on F12, it says something about...
Nov 24, 2009 | Dell Dimension XPS 400 PC Desktop
Dell Studio Xps 7100 Desktop Computer (AMD Athlon II X4 630 1500GB/8GB) (DXPDDY413) Logo
mukhtar21 shaikh
mukhtar21 shaikh
