How to reset riso 390 ui with a drum error - Office Equipment & Supplies
  • 19 Answers
SOURCE: drum stuck RISO RN2235ui
assuming you have a RN machine
you should of removed the master on the drum by hand if it was not used for more than a couple of weeks, and wipe dry under the clamp.
To get the drum out, hinge up the top of the machine over the top of the drum there is another small door, it hinges up like the top of the machine.
At this point ensure that the drum is in the home position i.e the clamp of the drum is at 12:00 (on top). if not turn drum to that point by hand.
Then try the button again to release the drum. If that fails there is a small **** under the drum at the front door area. there is a catch there that holds in the drum which you can move to the side with a flat screw driver.
Posted on May 19, 2009
iservice
  • 318 Answers
SOURCE: riso 390 has error code d4-534
The machine do not reconise the ink.At the back of the ink there is a electronic chip that tells the machine what tipe of ink it is.There is a problem with that chip or the ink is not compatible.Replace your ink in most cases this will solve it,but let me know if I can futher assist.
Thanks for supporting us.
Posted on Dec 12, 2009
  • 17 Answers
SOURCE: Riso 390 has error code d4-534
D04-534 means incorrect ink cartridge set. This could be caused either a) it IS the incorrect ink cartridge, or b) the RF tag that is struck to the end of the ink bottle is damaged. Try a new ink bottle.
Make sure to use RISO ink designed and made specific for an RZ230.
Posted on Mar 30, 2010
  • 17 Answers
SOURCE: Error Code -534 on my Riso RZ 390. Drum is stuck
  • 5 Answers
SOURCE: we have a riso gr 3770 the drum tray will not
under the drum tray there is a rectangular hole, try to actuate the sensor by flat screw
Posted on Jul 27, 2010
Why do not feed more than one or two pages
Check if there is dust or if the output is holding paper sheets to pass. It may be that some of the gear output paper is loosely screw on the shaft causing the problem. Also check the registration sensor inside the machine and clean it. I hope I helped you.
Jul 08, 2014 | Riso RZ390 Duplicator
Riso rz 390
There should be a built in head cleaner. I think you can access it through the control panel, then device and printers. right click on the printer with the issue, scroll down to printer properties. there should be a box that says "print test page" when the test page prints it should ask you if it is ok, this is where the clean head should be.
Jan 18, 2014 | Office Equipment & Supplies
Rn 2030 ui error code t-98-540
t98-540 Cannot read/write data to EEPROM in the print drum. hope to be of help.. EEPROM problem is eminent.
Oct 21, 2013 | Riso RZ220 Duplicator
Riso RZ 220 UI The master drum will not come out and the green light is not on.
This is for master drawer not responding to green light to be released question. Try turning ON machine (turn off first) while holding down the reset button. Also a mechanical way is a small hole to insert a pencil, eraser end first, just below green latch area. Just insert hold in while squeezing release latch. to drawer.
Sep 09, 2013 | Riso RZ390 Duplicator
Necesito bajar el driver de la riso rz 390 ui gratis
Please follow this link to download the driver from the original source - Riso:
http://www.risographie.de/riso/index.jsp?page=187&lang=1
Please notice that this site is in German language, but do not hesitate you will find what you need!
Apr 21, 2011 | Riso RZ390 Duplicator
Somebody that speak Spanish? Riso RZ 220 UI have a code that say P18 531. What is the problem?
P18-531 means: Print drum lock sensor is still ON even after 100 milliseconds after the print drum lock solenoid is activated.
Mar 16, 2011 | Riso RZ220 Duplicator
The riso rz 390 ui does not print the scans complete
Please check the setting of paper size. It may be set to a smaller format and therefore the outer original area is not transferred to the master.
If you meant someting other than please explain ...
Feb 03, 2011 | Riso RZ390 Duplicator
I have a Riso 390 ui RZ i did an electric chock accidentaly on my building the duplicator was working, but after the chock it smelled like smoke inside the machine now it doens't star what part do I...
You have a small circuit board. That is after the power source.Unplug and open the duplo.The circuit board you can order from Riso and have installed by an authourised technition.Good luck
Aug 13, 2010 | Riso RZ390 Duplicator
We own a Risco RZ 390 UI, and are not able to use it, due to a code that has appeared on the screen: Code P-19 What does this code mean?
This a proble with the Thermal print head. You will need to call service to repair. When you call press the point key to get the rest of the code.
Jun 16, 2010 | Riso RZ390 Duplicator
Error Code -534 on my Riso RZ 390. Drum is stuck in machine and won't release.
Jan 03, 2010 | Riso RZ390 Duplicator
18 people viewed this question
jasbo
jasbo
