Question about LG KG800 Cellular Phone
Alarm is no longer working
Alarm has gradually been turning itself off and now doesnt work at all?? When the time alarm is set for approaches the alarm function just turns itself to the off position without sounding and the symbol on the main screen - that tells you it is set - dissapears? This has been happening every now and again for the past month or so and now it doesnt work at all?? Any help that you could give me would be really appreciated - thankyou. x
  • 30 Answers
Sounds like sofware problem. try a factry reset. type 2945#*# on your main screen then just go to the bottom and the option is there. you will lose everything on your phone. if you really need the alarm that would be your best option as the options for the kg800 are very limited since its a closed source
Posted on Sep 05, 2007
SOURCE:
I have a phs8905 sharp watch and I can't figure out what AL is I think it's alarm but it doesnt effect anything. The bell symbol turns the alarm on and off but I can turn both the AL symbol and the bell...
A is for ALARM, when you want an alarm to sound just set the time you want to be woken or reminded of something then turn alarm on, an alarm will then sound at the time you set
Mar 02, 2018 | Watches
I have a 1996 HOnda Accord, and the car has an alarm. Most of the time i have to fight for some time to get the alarm to allow me to start the car
if the key itself doesnt turn its not an alarm issue its the ignition switch itself u need to replace it, it is worn out
Oct 28, 2012 | 1996 Honda Accord
How do I diengage the alarm on my 2009 Chevy Malibu? Its locking by itself and setting the alarm off. The key remote doesn't work.
Have you replaced the Batteries in the remote control??? Does your vehicle require a "smart" key???
Jul 30, 2012 | Chevrolet Cars & Trucks
Alarm set
this is a factory alarm, the problem is the alarm is active, you will need to use the door locks to turn alarm off, insert key in driversdoor and lock and then unlock door this will turn alarm off, if that doesnt work then use pass/side door, the lock has a built in switch that knows when the door is locked or opened, the driversdoor may have a bad switch so inturn the computer thinks the door was forced opened without key and it is turning alarm on, so again use the key to unlock door try the pass/side if driversdoor doesnt work. good day
Nov 24, 2011 | 1998 Plymouth Voyager
How do i turn off the alarm on my Samsung galaxy mini
Go to Settings > SOUND > Silent mode (No sounds except media and alarms).
If this is ticked (on), it means alarm will sound even if you make the phone silent.
Regarding the loud sound even after reducing ringer volume, no idea for this.
Oct 31, 2011 | Samsung Galaxy S GTI9000 Smartphone
Car alarm indicate led stay on all the time, although the lock and unlock work its a gm vsc3100 alarm system. Any help will be appreciate. Thanks
This is the aftermarket alarm may be time for a new set but before you go that direction the alarm light may have shorted to a power and not affecting the alarm itself by the way does the alarm horn work and is it diconnected because if it is it realy activated. If it isnt and alarm horn works but the light always stays on the the alrm internal relays doesnt switch over. The fix most area will make you get a whole new one
Apr 21, 2011 | Chevrolet S 10 Cars & Trucks
How to disable alarm system. The alarm went off
okay, this alarm reset is done by turning the key on and pushing the reset button a few times, you will need to try this a few times to get the correct number of pushes,for example turn key on and quickly push 3 times and if that doesnt work retrey it and push it 4 times, take note that every time you try you need to turn key off and then on again before you push reset button,i know it can be set to 1- 2 -3 or 4 pushes to reset, this is programed at the time of install, most installer dont set it or tell you so you will need to try all four. good day.
Apr 15, 2011 | 1996 Nissan Pathfinder
Cannot turn off the alarm
The problem appears to have resolved itself. The oly changes I made to the smartphone was to power it off and insert 16GB mini SD memory card. Since powering back up I have not had the alarm warning.
Nov 28, 2008 | HTC S620 Smartphone
Setting watch
Press and hold the top left button (mode) until the numbers start blinking. On mine this is the alarm time set. Press the mode button one more time to get to time set. The hour will be blinking. Press top right button (start/stop) to cycle through hour, minute, date, etc. and press bottom right button (adjust) to change the number which is flashing. Press mode to finish.
To turn off alarm, press and HOLD Adjust button, then press Start/Stop to cycle through alarms on/off.
Mar 25, 2008 | Timex 1440 Nylon watch
LG KG800 Cellular Phone Logo
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
