Question about Plumbing
Aquasource faucets instructions
Soap dispenser won't dispense soap
  • 235 Answers
SOURCE: soap not dispensing from pump
Try pumping it and covering the hole with your finger until pressure builds. This usually works. Soap is heavier than water and it takes a little longer to move up.
Posted on Jul 05, 2009
SOURCE: Price pfister soap dispenser will not work
I just replaced the pump innards with new and it's working now. Just for fun, I took the old one apart. There's a little metal ball bearing at the bottom of the chamber in the pump. The ball and the bottom of the chamber had a little rust and gunk in them. Since I've only ever put soap and water in the pump, I suspect it's either the metal spring and ball bearing rusting or some manufacturing debris left in the bottom of the chamber. The new one works fine but so does the old one. Now I have a spare. It was a little tricky getting the old one apart - I couldn't get the top to release, I just pried it off. Seemed to go back together OK so it should be fine if I need it.
Posted on Aug 28, 2009
  • 19 Answers
SOURCE: kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
Posted on Jul 07, 2009
SOURCE: The soap dispenser on my price pfister kitchen
Two things spell trouble for these poorly engineered units:water and thick soap...
Inside these pumps is a metal ball for
the check valve. any water in your soap
will corrode this ball, causing the pump
to lose it's prime...
Using soap thats too thick (like Dawn)
will cause the soap to harden around the moving parts and impede the pumping
action. Try a thinner soap, such as inexpensive pink hand soap.DO NOT
ADD WATER! (See above)
Hope this helps.
Posted on Jan 21, 2010
  • 35 Answers
SOURCE: Soap dispenser doesn't pick up soap
Make sure the clear tube is inserted into the pump head properly.Make sure the tube is not kinked. try filling the bottle full of water and try pumping the water out first. Sometimes the dispenser gets an air lock and takes a bit of continuous pumping to get it to work
Posted on Feb 25, 2010
Fix soap dispenser
remove the entire soap dispenser and clean out any dried soap which may be lodged in the pick up tube, blocking the pump
Aug 26, 2014 | Plumbing
Soap dispenser won't stay closed
Only two reasons this may happen. One is the dispenser is just bad (most likely) or that the timer is somehow malfunctioning and sending power to the soap dispenser all the time (least likely) You will usually know if its the second because the dispenser will get really warm after the dishwasher had been on for a few minutes.
Aug 15, 2012 | Asko D1716 Built-in Dishwasher
The threaded shank for the soap dispenser broke on our Price Phister model KSD-M1YY soap dispenser. Can't find a replacement. The model # of the faucet isT26-4DYY. Can you help?
Most parts can be ordered though Price Pfister Directly 1-800-PFaucet. Here is a link to the parts diagram for your faucet. http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/treviso/tret26-4d/ex-026-02.pdf  If by threaded shank you are talking about the bottle, then you can order just a new bottle (Part # 950-004) if not you may need to order a whole new soap dispenser (Part # 920-054.) If you order a whole new soap dispenser than make sure you order the correct finish to match your faucet.
Oct 09, 2010 | Price Pfister Marielle Kitchen Faucet with...
I bought a tuscany faucet from Menards and the soap dispensers plastic hose that screws into the bottle that you fill with soap cracked. Can I just buy a dispenser?
You can buy replacement soap dispensers at Lowe's, Home Depot and most home centers and hardware stores starting at around $22.
Aug 09, 2010 | Plumbing
We have the single handle Pegasus 190 571 Brushed Nickel bathroom faucet. The soap dispenser got knocked and broke off and I cannot find a replacement for it.
The booklet that comes with that unit has the following part numbers: nut set (A66D111); soap dispenser sleeve (A665597); soap pump (A605230); soap dispenser nozzle (A66596). Those are all the parts (less plastic tube and soap reservoir bottle) for the dispenser- you probably only need one (the broken one!).
Jun 17, 2010 | Home
Feb 24, 2010 | Price Pfister Marielle Kitchen Faucet with...
Soap dispenser on my Hanover 529-7TMS faucet won't pump soap.
it maybe that the soap is to thick,you must replace the unit.
Jul 16, 2009 | Plumbing
Soap not dispensing from pump
Jul 03, 2009 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
281 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
