Question about Philips Magnavox 20MT4405 20" TV
Black screen, high pitched squeal
I turned off my 6 mo old 20mt4405 a couple days ago and later when I went to turn it back on I got an almost entirely black screen with about 1/2 in line of color/video in the middle of the screen and it's making the most horrible high pitched squeal. Anyone know what caused this and how I can fix it?
  • lovelabs Aug 31, 2007
    Thanks. That's EXACTLY what's wrong, horizontal line. I called Magnavox again this morning, they said it was out of warranty (3 months labor and repair) and offered me an exchange for $57. Not sure if I should take it or not.
  • 398 Answers
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Posted on Aug 31, 2007
SOURCE:
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
`How do I fix my LG tv? It's making a high pitched noise and there is a black screen, is it fixable?
Get it to a tv dealer but my guess is its died. It may not be economical to repair but you may be pleasantly surprised and its a small job. LG are usually pretty good so I'm surprised its gone at this age.
Mar 30, 2015 | LG Televison & Video
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
High pitched squeel from the hard drive and then shuts down.
restart the computer HOLD the keys CTRL +F11 OR F12 depend of your mark, model, and go restore to the factory default, and fix it.
Passs the antivirus+antimalware very IMPORTANT!
God bless you
Jul 20, 2013 | Acer Computers & Internet
Blower stopped working on 2002 dodge caravan
Someone would need to check the blower motor and the resistor for voltage and ground.
Dec 09, 2012 | 2002 Dodge Grand Caravan
High Pitch Squeal In My VS65R
This is only a guess on my part, but if the potentiometer you replaced is part of the feedback loop and either of the outside legs are open, the circuit will be infinite gain and have a parasitic oscillation you describe; many gain circuits in pro gear are configured this way. Also, since you did replace the pot, it would be easy for you to check this first to make sure these connections are secure as it may not be a co-incidence, but still related to the original fix. Hope that helps.
Oct 22, 2017 | Music
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
RCA 50" - Convergence problem and now "Popping" + no picture
The high pitch popping that you are hearing is arcing in the high voltage circuit. I would not suggest a repair on a set that is this old. Convergence repair plus a high voltage problem could run around $500-$600. But it is your call on the repair, I can only advise.
I hope this helps you.
Thanks for using FixYa
asnowman
Sep 23, 2009 | RCA P50830BL 50" Rear Projection...
Polariod FLM-3232 Screen Flicker & High Pitch Squeal
replace all the capacitors in the power supply
board.you will see the capacitors bulge out on the tops.change all of them with a higher
voltage.
Aug 08, 2009 | Polaroid FLM-3232 Television
Philips Magnavox 20MT4405 20" TV Logo
236 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
