Rheem RHQA-0805B filter size - Heating & Cooling
2 Suggested Answers
  • 30 Answers
SOURCE: Getting new system How many Tons would a Rheem Air
The Rheem model RHQA-0805B is a 6-ton unit.
Posted on Aug 02, 2009
Rheem Imperial 90 plus furnace filter size model# RGEA 10EC-FS
Measure the housing that the filter goes in, reason being it is not the same in every installation.
Oct 21, 2016 | Filter Heating & Cooling
What airflow does RHEEM RGLN 07eamer Furnance have? Is it downflow or upflow?
looks like Downflow
Rheem Classic Series Downflow Gas Furnace cdn.globalimageserver.com/fetchdocument-rh.aspx?name=rgln... · PDF file Rheem Classic® Series Downflow Gas Furnace FORM NO. G11-519 REV. 1 RGLN- Series ... RGLN- SERIES 05EAUER 05NAUER 07EAMER 07NAMER Standard Filter ...
Feb 18, 2016 | Filter Heating & Cooling
I need to know what size rheem filter for a rcgj-36a1g
Just take a tape measure and measure the return opening and that will give you the size. length and width.
Jul 13, 2014 | Rheem Rchj-36a1g 2.5 Ton Ac/hp Uncased...
I have a rheem classic 90 plus rcba 3765gg17 in my condo. What is the filter size?
Mike I would contact Rheem directly or just take it out and go to a store and match it up
You could do a search but think the other two ways will be a lot faster
Oct 19, 2013 | Heating & Cooling
I have a Rheem rhqa 1010 b and need air filter size.
Just measure the filter housing (LxW) and buy it at walmart, lowes, hom depot etc.
Oct 07, 2013 | Heating & Cooling
I have a RHEEM RHQA 1010B a/c unit that is pouring water out of the bottom....please help find cause and solution. PS it is very humid where I live!!!
Hello, usually water will leak from a furnace if the condensate line is clogged, or the condensate pan is cracked. If you have a shop vac try to hook it up to the outlet of the drain line and use the suction pressure to remove the sludge that is clogging it up. If the drain line appears to be clean the most likey the condensate pan is cracked or rusted and causing the leak.
Jul 13, 2011 | Heating & Cooling
Rheem air conditioner RHSL-HM3617JA how do I change the air filter
Air filter tray is integrated into the unit.
There is a door on the face at the bottom.
The door pops open and the filter slides out from the side.
The filter is MERV 8-13 depending, size 17.5x21x5 (17.25x20.75x4.38) It costs 30-70 dollars, but changing is very easy.
May 13, 2011 | Water Heaters
How old is a rheem rhqa-122oj air handler and what is the max wattage.
ampsxvoltage=watts so if you know the amp draw should be on machine and voltage just multiply as far as age undetermined
Feb 02, 2010 | Heating & Cooling
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
