Question about Cerwin Vega LW12 Subwoofer
Fuse my cerwin vega sub has a problem. ive had the thing for years and i love it but the fuse has blown out. everytime i buy a new for it,it keeps blowing right after i turn it on. i buy the fuse it says but they keep blowing. i dont want to get rid of it. help please
ravichetty
  • 158 Answers
SOURCE: it keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Posted on Jul 22, 2009
  • 29 Answers
SOURCE: I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Posted on Nov 01, 2009
technical114
  • 1851 Answers
SOURCE: I have a cerwin vega subwoofer that keeps blowing the fuse
Take a look at the Voltage selector switch (if one is existing). It may be switched at the wrong position. In that case, I hope that the power supply is not burned out (if it is set at the wrong position).
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jun 13, 2010
  • 357 Answers
SOURCE: Got a cerwin vega cls 12s keeps blowing fuses. It
by the sounds of it the internal transformer could be duff. You need to take readings from the transformer using a multimeter to check correct voltages are coming out of the transformer to their destinations. I would also chek the capacitors and other components on the chain pre and post transformer to make sure none of them are damaged too.
IF YOU ARE NOT EXPERIENCED WITH MAINS ELECTRONICS DO NOT ATTEMPT THIS YOURSELF!!!!
Posted on Jan 08, 2011
Bennytechkid
  • 99 Answers
SOURCE: My husband seems to have
Hey
it's a 2.5Amp Slow Blow 2AG fuse..
Most electronics stores stock fuses..also to being a 2AG fuse they are exactly the same as the old auto fuses and thus most auto stores carry them in stock aswell..
but remember.....Fuses blow for a reason
and NEVER put a bigger fuse in!!!. try and find the fault....unless he has just cranked it too much :-)
hope this helps!,ben
Posted on Jan 13, 2011
When turning on the power on my cerwin vega 15" sub the protect light which is a built in protection on the amplifier keeps coming on the power on light does not come on at all just the protect light
The sub could be shorted or the wire connections of the sub could be shorted, or there could be an internal problem with the amplifier such as a shorted output stage or failure of some other component(s)
Feb 21, 2013 | Cerwin Vega Audio Players & Recorders
I had just baugh a cerwin vega stroker car sub and its making a noise and the front part of the sub came off wats the reasion is it my falt I just baught the sub two weeks ago?
Factory Reject. Those things are suppose to be Tanks. I would exchange it for a new set. Thay are some ROCKen speakers. Dont forget your proof of purchase.
Feb 26, 2011 | Cerwin Vega STROKER 18D218" Dual 2ohm...
My husband seems to have blown a fuse in our cerwin vega E712 speaker. please advise the model fuse we will need to replace it and were we can purchase the fuse.
Hey
Jan 13, 2011 | Cerwin Vega Audio Players & Recorders
Cerwin vega avs sub8. no power. changed blown fuse and still nothing. no power light indicator. unless led light bulb blew which i believe to be unlikely it has no power. any ideas
I got the same problem, my sub was working perfectly and suddenly one day it did't turned on, so I think it is the protection from the internal transformer, it needs to be changed but I don't know the model, if someone else knows I would appreciate the info because it is a really good subwoofer for the size...
Jan 07, 2011 | Cerwin Vega AVS-5.1 System
Thanks and regards
Stelios
Jun 13, 2010 | Cerwin Vega CLSC-12S Subwoofer
No sound coming out of speakers on my cerwin vega
spurdoggg,
It will be easy to pin point the problem. If your satellite speakers have been connect through the sub's in and output speaker connectors, disconnect them and connect them directly to the source of sound. If the speakers work its the crossover inside the sub enclosure. If the speakers do not work the speakers are blown.
Apr 28, 2010 | Cerwin Vega AVS-5.1 System
I have 2 cerwin vega hed 12" subs , whats the most power of amp i can buy two power them both
if you can afford it, get a pheonix gold amp, cerwin vega's are hard hitters and need lots of juice. get yourself a 1500-2500 watt amp, you will be pleased
Jan 12, 2010 | Cerwin Vega HED-12 Car Subwoofer
It keeps blowing fuses - two 12 inch cls subs 1
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Cutting on and off
Same thing is happening to my Cerwin Vega 18" sub. Can't find solution at all. Guess I will have to buy a new sub.
Jun 19, 2008 | Cerwin Vega LW12 Subwoofer
Cerwin Vega LW12 Subwoofer Logo
75 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Joe Lamb
Joe Lamb
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
