Question about Euro-Pro EP1005 Iron
Manual I have euro pro ironing solution model 1000 .a video came along but I haven't got VCR to watch . I'm wondering if I wouldn't see it online
SOURCE: Manual for Euro-Pro G6118H
I don't know if you have the number for the euro pro customer service department; but, I had the same problem, called customer service, and had a manual emailed to me. The manual came within a couple of hours via email. In case you don't have the number and still need a manual for your unit, try calling 800.798.7398. I hope this helps and good luck!
Posted on Jul 18, 2008
SOURCE: Shark Euro Pro Iron turns
I was having the exact same problem. It happened infrequently, then over time it got worse. I would jiggle the cable to get it to turn back on again, and that worked for about six months. Eventually the iron was unusable, I had to hold the cable in one spot and it would go on for about 30 seconds, then die out.
I decided to go on a little adventure inside the iron to see what the problem was. I was convinced the cable was frayed on the inside from rotating so much. After unscrewing the bottom, I found there was plenty of rust inside the iron, which had gotten all over the contact points from the AC cable from the wall connects to the heating element. If I moved the cable back and forth, I could hear it sparking and get a good connection.
It doesn't appear that the rust was from water leakage inside the iron, but rather steam produced while ironing. After cutting the wires and soldering the connection, the iron works fine again. It took about 1/2 hour to do from start to finish.
I would recommend getting a different brand, it only took mine a year from purchase date to fail.
Posted on Oct 02, 2008
  • 19 Answers
SOURCE: shark euro-pro iron cord replacement model 4750
six screws on bottom plate two hidden under rubber feet on bottom under lower screw holes
Posted on Aug 16, 2009
SOURCE: euro-pro EP1005 iron--iron heats -blower works-but no steam
You may not need a new iron, my wife's iron is doing the same thing. take the top of the ironing board off (you will need a torx t-20 security bit driver), under the tank is a connection that may have rusted out re-connet it and turn the iron on. Once it heats up, check the tank for leaks. The tank may need to be replace as well or try a 5-minute epoxy type glue on the leaks once it has cooled. If the tank leaks you will get not get enlugh pressure building up to get the steam.
Posted on Jan 05, 2010
caroldon
  • 17130 Answers
SOURCE: A manual for as Euro-Pro electric iron model EP
You may not be able to get some manuals from the website but if you are able to call their call centre some assistance could be got from them.
Their customer service number is: 1-800-798-7398
Posted on Aug 31, 2010
My euro pro ironing solution model 1000 does not heat up or allow steam to be released. It does make steam. What could be wrong?
The steam passages may be clogged, especially if ordinary water containing minerals was used to fill it. The instructions for your Euro-Pro iron probably specify use of distilled water.
Aug 24, 2016 | Irons
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
May 29, 2016 | Euro-Pro Irons
I have a Eurp-Pro 1000 ironing system. I need a new board cover and a manual
the instruc. manual download from www.fitness.manualsonline.com or www.retrevo.com
the parts go www.repairclinic.com or www.appliancepartspros.com
God bless you
Jul 18, 2012 | Irons
A manual for as Euro-Pro electric iron model EP 470
Aug 31, 2010 | Euro-Pro Irons
Euro Pro Steam Iron
I'm having a problem with a Euro Pro Steam Iron as well. Thier customer service phone number is 1-800-798-7398. Hope this helps
May 13, 2009 | Euro-Pro Steam Generator EP8001 Iron
Shark euro-pro iron cord replacement model 4750
Nov 18, 2008 | Euro-Pro Shark GI490 Iron
Shark euro pro G 1400z
how do you replace the light bulb on a shark euro-pro iron?
Oct 27, 2008 | Euro-Pro Shark GI475 Iron
Euro-Pro EP1005 Iron Logo
82 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
