Question about IBM Wheelwriter 3 Electric Typewriter Type 674X
How to replace cracked plastic print solenoid cap
IBM Wheelwriter 6 typewriter. The print wheel does not move when typing and acts as if in stencil mode
From your posting it sounds like you have cracked plastic print solenoid cap. We sell them for 20.00 with instructions.
DickyO
216-269-3918
Apr 29, 2014 | IBM Wheelwriter 6 Typewriter
How do i increase the force of the hammer hitting the daisy wheel?
Code "Q" will increase the impression the space lights indicate i, 2 or three. a little WD 40 on the print solenoid may help. But I believe tour loss of impression is a cracked plastic print solenoid cap. We sell them for 20.00 including shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
Feb 17, 2011 | Lexmark Wheelwriter 1500 Typewriter
How to replace Wheelwriter 5 Hammer Solenoid
I doubt very much if the solenoid is bad. You probably have a cracked plastic solenoid cap. We sell them with instructions and shipping for 20.00.
DickyO
216-241-0027
Jul 01, 2010 | Lexmark Office Equipment & Supplies
How do I make key srrike harder on an IBM Wheelwriter 6? The print is to light on carboned forms.
If it prints well on 20# bond and the carbons the problem may well be the paper the forms is printed on. Otherwise the print solenoid cap may be cracked. You can try a Lexmark Brand #1380999 for hard to image paper. There are some circular plastic shims on the front side of the solenoid, remove one and it will print darker. If you need the solenoid cap we bsell them with instructions and shipping for 20.00.
DickyO
216-241-0027
Mar 29, 2010 | IBM Office Equipment & Supplies
Hello: I have a IBM Wheelwriter 50 Series II. Today, I was priting a letter in storage of about ten pages, and about half way thru the print turned lighter, parts of letters didn't print at all, and then...
The print solenoid is either gummy or the plastic cap on it is cracked. First try spraying some WD40 on the back side of the solenoid. It is located below the ribbon just inside of the left printer side frame round about 1.5" in diameter. if the dosen't work
We sell a print solenoid cap with shipping and instructions for 20.00.
DickyO
216-241-0027
Mar 12, 2010 | IBM Office Equipment & Supplies
Only top half of characters are printing on my IBM wheelwriter3. Have I accidentally hit/moved some part. If so, how to correct.
Press down firmly on both ends of the platen (black rubber roll) it should snap into place. If that dosen't work the plastic cap on the print solenoid is probably cracked.
We sell them for 20.00 includes instructions and shipping.
DickyO
216-241-0027
Jan 05, 2010 | IBM Office Equipment & Supplies
Letters are not printing fully.
First press firmly down on both ends of the platen it will snap into place if it has worked out of place. If that dosen't do it the plastic cap on the print solenoid is probably cracked. We sell them for 20.00 includes shipping and installation instructions.
DickyO
216-241-0027
Oct 20, 2009 | IBM Office Equipment & Supplies
Ibm wheelwriter 5
yes it was true that the cap was broken. temporarily, i just cut a piece of plastic from a spoon, same thickness as the cap then place it between the plunger and the solenoid. and now my wheelwriter is typing great! all letters are clear and much black in color. thanks for pointing where the cap was place. easy to find it.
Apr 01, 2009 | IBM Office Equipment & Supplies
Typewriter turns on keys work ,new ribbin, but when you hit the key no type shows on the paper
The problem is probably either a broken plastic cap on the print solenoid or a gummy solenoid. the sol. is round and just unside the L. peinter side frame. Try a little WW40 on the front and rear ends of the solenoid if it doden't work the cap is probably cracked. They are available but a little tricky to install.
Hope this helps
DickyO
Jul 10, 2008 | IBM Wheelwriter 30 Typewriter
Ibm wheelwriter 5
Most likely the plastic cap on the print solenoid is broken they are available but are a bit tricky to install.
DickyO
Mar 27, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3 Electric Typewriter Type 674X Logo
48 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
