Question about Hoover Vacuums
Charging hoover presto 2 in 1 first time - Hoover Vacuums
Where can I get a mother board for a Freejet 3in1 cordless hoover model FJ180WB2
probably need too replace the whole board. safest way in case board is at fault. Appliancepartspro.com with model no.
May 02, 2016 | Hoover Vacuums
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ā€ˇReview by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
My hoover presto vacuum wont charge
Either the charger or battery is defective.
Mar 23, 2015 | Hoover Vacuums
Troubleshooting hoover
Hi! Here are some basic trouble shooting steps for the Presto 2-in-1.
1. Remove the dirt cup. Push the release catch on the hand vac and pull the dust container off the motor unit
2. Remove dust container from filter assembly and cyclone separator.
3. Hold the dust container over trash can and tap out debris.
4. Check cyclone separator for additional debris, empty into trash can
5.Check the rinsable filter. If rinsing is needed, remove rinsable filter, rinse with pleated side facing up. Allow filter to completely dry for at least 24 hours.
6. Remove any hair and debris from the brush roll.
7. Remove the floor nozzle from the cleaner by pressing the nozzle release button on the back of the floor nozzle and pulling from cleaner.
8. Check and clear nozzle of any obstructions.
Hope this helps!
Aug 06, 2014 | Hoover Vacuums
Battery for Hoover Linx will not charge. Charger blinks very fast.
Jan,
your battery is Shorted. it is time to buy a new vac or a replacement battery.
sorry that is such a short hand answer but that is what the charger is telling you.
Apr 22, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
Where is battery compartment
Hey Ashish,
I have attached a link to the users manual for your Hoover vacuum. You can find a diagram showing where the battery is on your unit and where the charging port is.
http://hoover.com/file/341/
You can purchase replacement filters direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/hoover.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jan 23, 2014 | Hoover Presto Stick Vac, BH20095
How to install broken belt
Why would you want to put in a broken belt?
Turn the machine upside down. There are two clamps that hold the sole plate on, un click then. This will reveal the 'belt alley' where the belt runs from the motor to the roller. Lift the roller out of the slots. Take this time to clean all the hair and threads off the roller.
Put the new belt over the wooden pulley on the roller and put it almost back in. Put the other end of the belt over the motor shaft. Stretch the belt by returning the roller to its slot. Put the sole plate back on - snap the clips - Presto.
Simple
Thanks for your question today.
Feb 03, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover FloorMate won't pick water up
Check for the filter in place and it also requires a filter lid for proper suction or it will not work
Jan 23, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Brushes on My Hoover Steam cleaner will not spin
We had same problem,Had to have bearings replaced at hoover store/service center. If you bought it within the last year it is under warranty and you wont be charged.
Nov 24, 2008 | Hoover SteamVac F5914-900 SpinScrub...
My henry hoover has just stoped working its not the fuse do you have any ideas
I had exactly the same problem.there were no burning smells coming from it so nothing seemd obvious.I then took it apart and checked that all wires were connected,which they were.Then decided to check the plug.After replacing the fuse I chopped the cable of (as it is a seald plug) and connected up a new one.Hey Presto,Henry was alive again.Hope this helps.
Nov 03, 2008 | Hoover Vacuums
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
