Question about Sewing Machines
Juki serger having trouble with thread(s) breaking on my serger (juki mo 103N) it serges for about 8" beautifully then breaks again. any solutions?
4 Suggested Answers
SOURCE: juki mo 2316 nEEDLE THREAD KEEPS BREAKING
I took my machine in to a place that fixes machines.
Thanks anyway!
Posted on Sep 10, 2009
  • 1116 Answers
SOURCE: Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Posted on Feb 19, 2010
SOURCE: JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Posted on Nov 18, 2010
Juki Serger - MO-50e thread will not move out of the machine and continues to tangle under the needles. Please help! The machine worked beautifully for a few hours and now it is a really expensive p
I have had this happen, check your tension on that thread and check the thread thickness. Tofix mine I recall changing both,and I think it was the thread thickness in relation to the tension
Oct 29, 2014 | Juki America, Inc Juki MO-50E 3/4 Thread...
SERGER HAS BEEN RETHREADED AND HAS A NEW NEEDLE BUT WILL ONLY SERGE FOR ABOUT 1.5 " and THE THREAD BREAKS AND LOWER LOOPER COMES UNTHREADED.
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding off the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Aug 21, 2013 | Singer 14SH654
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
JUKI MO 134 SERGER
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
Feb 19, 2010 | Juki MO-734DE Mechanical Sewing Machine
Looking for an online manual for my Juki serger MO-634DE
Herre is a link to the threading diagram: http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_634_Threading_Diagram.htm
Oct 08, 2009 | Juki MO-644D Mechanical Sewing Machine
Juki mo 2316 nEEDLE THREAD KEEPS BREAKING
Thanks anyway!
Sep 09, 2009 | Sewing Machines
I want to have my Juki MO-2516n do a mock safety stitch/4 thread
I have a Juki MO 2516N. It does not have the capability to serge 4 threads. The only options are 2, 3, and 5.
Apr 28, 2009 | Juki Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
