Question about Refrigerators
Have a turbo maxi cool bar refrigerator. Light comes on inside compartment but will not get cold at all
  • 87 Answers
SOURCE: refrigerator doesnt get cold enough
If you remove the back panel on the inside of the cabinet then you would be able to check the evaporator coil (cold bit) and see if it is frozen up. If it is then defrost the system and see if you have any improvement. All the things you have pointed out over the compressor is normal, they do run incredibly hot. If you have got the freezer on a very cold setting I would suggest bringing both setpoints to a mid range setting. Check the temp in the fridge by measuring liquid temp as air temp is prone to fluctuate more. If you still have a concern I would suggest contacting a fridge guy to assist you. Hope this is of some if not limited help.
Posted on Sep 11, 2007
SOURCE: Ge Side by side model PSS26MSRSS
I had the same problem with mine, but I bought the 5 year warranty from Sears. They sent me a new board (Part Number WR55X10552) and the problem stopped. This is a common problem from what the guy at Sears told me. I put the board in myself in less than 20 minutes. It's a very easy job. I saw a few of these boards brand new on Ebay for $55.00. The board is different than the one that came with the refrigerator. It's been updated, so now when you open the doors the fan motor stays on (mine always shut off when I opened the doors with the old board). Good luck!
Posted on Sep 23, 2007
SOURCE: Freezer quits working
Solution Found! The problem is when the temperature surrounding the refrigerator in the garage falls to < 45 degrees, the thermostat regulating the refrigerator will not call for the compressor to kick in to provide cooling (it's temperature requirements are being met). Since there is no demand, the compressor will not cycle, which is how the freezer is kept cold, and the freezer eventually warms up to match the refrigerator temperature. Frigidaire makes a "Cold Kit" that I ordered and installed from RepairClinic.com for $22 (Item #: 1037646; Description: Garage kit). It's basically a strip heater that runs off the control power to warm the thermostat and causes the compressor to cycle once to twice a day to keep the freezer frozen. After installation, the refrigerator stays at 40-45 and the freezer stays around 0 degrees.
Posted on Mar 19, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
heatman101
  • 43501 Answers
SOURCE: Maytag model # mbf2254hew bottom freezer refrigerator
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
Why is the water coming out of the dispensor not cold
Is your fridge compartment temperature in the region of 2 ~ 6 C range. Is your fridge food not going bad. Then dispensor water should be cool. Cool water tank is normally hidden inside fridge compartment. Lowest temp is around 2 ~ 6 C range.
If you keep on taking water rapidly then there is no time for the cooling tank to cool. You are just pushing house water through the water dispensor.
Oct 03, 2014 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Why is my haier refridger not getting cold
There are alot of things that can cause no cooling...
a stuck tstat, will cause it to freeze up(electronic control)
a broken defrost timer will cause ice build up from no defrosting
out, or low on freon charge
inefficient compressor
door gaskets leaking
light switch not cutting off the light inside the cooling or freezing compartment
a bad fan motor(door) switch
I dont know how your unit works, but most only have one evaporator in entire unit..and its in the freezer compartment, and the cooling side gets it (coldnest) from the freezer compartment..with a door flap that alows cold air from the freezer to enter the cooler side.
Hope this helps..
Jun 04, 2014 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator not cooling FRS22WNC
the damper vent door between the freezer and refrigerator isn't opening to let cold air into the refrigerator compartment from the freezer side,its in the upper left corner in the refrigerator behind a grille,if its closed you wont feel cold air flowing in from the freezer sometimes you can shine a light in this area and look in the other compartment and if no light then the doors shut and this is why its not cooling the refrigerator
Sep 29, 2012 | Frigidaire FRS23H7C Side by Side...
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
No Display, no light on refrigerator side
If the refrigerator compartment light does not come on but the refrigerator is cooling, make sure the light switch inside the refrigerator compartment or freezer compartment is not stuck in the closed position.
The light switches (on some models) are located on the ceiling inside the freezer compartment or on the outer wall inside the refrigerator compartment. I usually try flicking the switch or unjamming it with a small pin.
Hope this helps
Ryan
May 22, 2011 | Whirlpool Refrigerators
Refrigerator compartment is not cooling. No air
your air deflector isn't opening up between freezer and refrige to let cold air down
Nov 01, 2009 | Maytag MFD2560HES Bottom Freezer French...
Fridge not cold at all.
check the adaptive deffrost control inside of the refrigerator compartment, more than likely thats bad.
Apr 05, 2009 | Freezers
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
