Question about Refrigerators
Will universal defrost timer work for avanti ff8y
Need defrost timer for Avanti ff8y refrigerator. will universal timer work?
4 Suggested Answers
  • 340 Answers
SOURCE: Avanti refrigerator not cooling
thermostat set ? might not be defrosting all the way. damper actuator not opening from freezer to refrigerator. is the condenser clean?
Posted on Jun 17, 2009
milten1
  • 1304 Answers
send me your model number and manufacturer ill tell you the code
Posted on Oct 27, 2009
  • 11800 Answers
SOURCE: I have an Avanti refrigerator
Directly from Avanti. Go here
http://www.avantiproducts.com/parts-accessories/current/no
click on your model (trial and error until you locate the correct one) and an pdf with an exploded parts diagram and a list of part will open - find the codes for the shelves and order them .
Posted on Jul 28, 2011
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Where is defrost timer located on avanti refrigerator model ff511w
The evaporator fan is probably not running and blowing the air from the freezer to the refrigerator.
May 25, 2014 | Refrigerators
Avanti error code e2 wine chiller, what is the problem?
Display flashes Error message "E2" - Defrost sensor (Coil Sensor) failure.
Contact the Avanti Service Department - 1-800-220-5570
Hope helps.
Jun 03, 2011 | Avanti WC42 Wine Cooler
I have a Avanti wc492d wine cooler that is not working. The unit shows power(lights are working) but it will not cool at all. I can here a click sound when I change the temp set, but the cooler will not...
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
Jan 28, 2011 | Avanti WC492D Wine Cooler
My freezer is working fine but the fridge is not cold at all. Not sure what could be the problem. Its an Avanti FF501W
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | Avanti FF501W Top Freezer Refrigerator
My Avanti refrigerator model #ff110 120 the freezer is 30 degress and refrid. is 60 degrees I have defrosted and unplugged for 24 hrs and still have same problem please help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 09, 2010 | Avanti FF1101W Top Freezer Refrigerator
My Avanti refrigerator (about 12 cubic feet) is freezing everything in the refrigerator section.
heatman101
Sep 07, 2010 | Avanti 248Y Compact Refrigerator
Avanti refrigerator
Oct 27, 2009 | Refrigerators
After 1 or 2 weeks the refrigerator stops working, it freezes up. After defrosting, works perfect for 1 to 2 weeks again
Defrost heater bad, defrost thermostat bad or Defrost timer. Defrost heater and Thermostat can be continuity checked. Defrost thermostat can only be checked if at freezer temperature. Both should show continuity if good. If those two test good the process of elimination means it's the defrost timer. Always unplug refrig when performing these checks
Aug 22, 2009 | Avanti FF511W Top Freezer Refrigerator
Jun 17, 2009 | Avanti EC15W-2 Compact Refrigerator
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
