Question about Canon imageCLASS D761 Copier
Canon np6030 copier
When i turn on the power button, the copier makes a sound like its trying to start up for about 1 second, but it doesn't start up.could this be the switch or is there some other component like a relay. please advise
  • davidb2b Aug 29, 2007
    when i turn the power button on, nothing happens,
    what might it be????
  • pu2s Mar 02, 2009
    when i turn the power button on, nothing happens.
  • 62 Answers
Does the machine start and switch itself off? Some errors cause this to occur to prevent further damage. Try switching it on with the front door open, this will prevent the fixing heater circuitry from initialising. You will then need to find the error code. The ones that cause it to switch off never appear on screen, only viewable thru service mode. Push a straightened paper-clip into the hole below the right hand meter inside the front of the machine, press << and >> to get to *1* DISPLAY, find ERROR and let me know. Hope this helps...
Posted on Aug 29, 2007
  • Bleddyn Jones Aug 30, 2007
    There is a circuit breaker on the rear of the machine, towards the finisher/exit side (I think). Make sure this is in the ON position. Push indent to test too.
SOURCE:
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
Canon pixma mp 160 printer is not printing it just shows E & 5 altenately.Please solve the problem Jayaram
1/ Turn off the canon printer
2/ Hold down the Stop/Reset button
3/ Not releasing the Stop/Reset button, hold down the Power button, now release the Stop/Reset button
4/ Not releasing the Power button, double click Stop/Reset button and release both the Power & Stop/Reset button - doesn't matter in which order
5/ Click Stop/Reset button four times
6/ Click the Power button to confirm the selected action (reset counter absorber)
Aug 08, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Errer code 5
Aug 02, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Canon pixma mp800 manual Pixma MP800 Printing cannot be executed because the lock switch is on. Question where is the lock switch ?? Release the scanner lock? Where is the scanner lock and how can I...
Doesn’t sound like your are making it into service mode, make sure the inner door is all the way up, make sure the top is closed, make sure both feeders have paper in them, make sure to turn off the power but do not unplug it. Start by pressing the stop/reset button first and then power button.
Aug 14, 2010 | Canon Pixma MP800 All-In-One InkJet...
Code error E002 for Canon NP6030
hi 1. cheq the fuser heater lamp & thermal fuse,
2. enter in the sim mod by pressing service swich located in side the front cove you can see the $ sing at the screen left upper corner then press *4* then scroll to find the error then ok macine will re start and hope your error will go
thanks
May 13, 2010 | Office Equipment & Supplies
Canon np6030
Most likely, you have a problem with the scanning lamp.... When you turn the copier on, will it turn right off? If so, try to hold the power switch "ON". The Display pannel will flash a Error Code... It may be a E0200 or E0220 or E000. Get the Error Code and get back to us... I think you have a heat or scanning lamp is shorting out... Good Luck
Mar 28, 2009 | Canon NP 6035 Copier
Message error E901:press the power switchto off then back to on
cassette feed unit motor or control board are faulty. or something is interfering with it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
Dec 27, 2008 | Canon imageRUNNER 5020 Copier
NP6030 copier manual availability
you may get lucky on this site
http://www.eserviceinfo.com/equipment_type/Copiers_58.html
otherwise you need to buy it, there are son=me good sites, and cheap $12- up
Aug 11, 2008 | Canon Office Equipment & Supplies
My canon ip2000 won't reset
Canon IP 2000 / reset Hi there you can try this.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
All the Best Pineworks
Apr 06, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon NP6030
go to service mode then press *4* and clear ram and enter same values displayed in *3* (please note old values of your machine in *3*before clearing ram)
Jan 14, 2008 | Canon imageCLASS D761 Copier
Canon imageCLASS D761 Copier Logo
448 people viewed this question
Clive
Clive
old marine
old marine
Ekse
