Question about LG Dryers
LG DLG 7188 WM will not heat
Cleaned the vent. There was a lot of debris. Installed new vent hose. When I start the cycle, I can hear the gas ignite. It sounds like it burns for about five seconds and then shuts off. Could this be the thermal fuse? Igniter? Regulator? Is this something I can figure our and fix myself?
jsrock516
  • 5911 Answers
SOURCE: After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Posted on Apr 29, 2007
  • 177 Answers
SOURCE: SPEED QUEEN MODEL AGS68AWF-- I'VE
If the glow bar is cycling off and on the glow bar works and the black box on the side of the vent are working, Either there is no gas to the dryer, doubltful but something to check or, You need a gas valve.
I would check for gas first, do you have other gas appliances? and all are functioning properly? Check the gas line and make sure someone hasnt accidently turned off the gas. If it is none of these you need a gas valve.
Go to repairclinic.com or partselect.com with your Sp Q model number, or the part number off the gas valve, it could be a five digit 58**** or 51***** number. Get you best price. Im guessing 80 to 100 Amercian
When replacing the gas valve, unplug the dryer first, turn off the gas, remove the front panel, two screws lower front panel, you will need a crescent wrench for gas line of side and a 5/16 nut driver remove wires. Now remove the orfice from the old gas valve and make sure you install it on the new valve. Is this a Natural Gas or LP Gas dryer?, If it is LP make sure you make the conversion to LP. Ask if you have more questions on this.
install gas valve, tighten gas line turn gas on check for leaks! with a bubble solution, start dryer and make sure dryer works properly.
best of luck
T
Posted on Jul 10, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Posted on Sep 12, 2008
onthejob5130
  • 640 Answers
SOURCE: Gas dryer not heating
it seems you have a lot of knowledge,,,i ran the schemtic,,and the only thing i could see that could be,, bad thermistor,,or the microprocessor control went bad..keep me posted onthejob
Posted on Jan 10, 2009
  • 61 Answers
SOURCE: Kenmore Dryer only lights gas sporaticly
replace the igniter. The ignitor is the most comon problem with gas appliances checking continuity does not tell you if it is bad or not it has to draw a certain amount of amps to open the gas safty valve and the is no safe way to check this on most gas dryers
Posted on Jan 19, 2009
Where is the drain filter on lg 4408dle
Lg Washers have model numbers that start with WM
LG dryers start with either DLE(electric) or DLG(gas)
so check your model number and add comment below
May 01, 2017 | LG Washing Machines
Dryer is not heating and it says check filter. What does that mean?
there is a lint filter that needs cleaned . usually every time you use the machine check this link LG D1102W Owner Manual Page 35
Apr 06, 2015 | LG DLG5002W 27" Gas Dryer
Carburator leaks gas when cycle is started or running from what looks like vent hose?
Sounds to me like your float valve is obstructed by some debris. This is causing it to stay open and leak fuel. Better it leaks to your vent hose than it leaks in your engine and contaminates your oil.
You need a proper carb cleaning. Not some run in the gas tank sh*t. If the tank wasn't full when parked, chances are there is rust in the fuel system to get this out you need to disassemble the carburetor and thoroughly clean it.
Try not to ride the bike til you do this. It's a fire hazard.
Oct 08, 2012 | 2005 Honda VT 600 C Shadow
Dryer takes too long to dry clothes. Heating element is working because clothes are hot but it takes almost 2 dry cycles to dry clothes.
It sounds like you're lacking air flow. I'm sure you're cleaning the lint trap / filter - but have you clean the VENT HOSE / PIPE?
The 4 in vent hose is supposed to be cleaned annually. If you have the flexible vinyl hose, replace it with either steel, aluminum or flexible aluminum tubing instead. Once you've removed the vinyl hose, it will collect a lot less dust and can be cleaned without worry of puncture.
A typical dryer vent brush.
Make sure there's no obstruction to the flap outside, too. Once cleaned the dryer operation should be restored to new again.
I hope this helps & good luck! Please rate my reply - thank you.
Mar 09, 2011 | Dryers
Gas Dryer lights but not drying. I have a White Westinghouse gas dryer on natural gas. It has a new vent hose and the filter screen is very clean and the vent area in the door is very clean. I even...
Sounds like the dryer coils are failing. The dryer may heat up in the beginning but once it runs for a few minutes the coils fail to open and let gas in. Check to see if you can hear the flame ignite after it has been running for a little while.
for a free video on this got to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Dryers
Gas smell from outside vent, but heats up fine, it is a maytag performa gas dryer. the igniter was just replced and i checked all connections with soapy water
It may not be burning clean. First thing you have to do is make sure that you dryer is vented right.
  1. make sure the vent pipe is not kinked, bent to sharp.
  2. Not full of debris.
Venting is important if it is abstructed then the gas backs up..
you may need to adjust the flame of the burner.
Sep 13, 2009 | Dryers
Frigidaire gas dryer trouble shooting gas dryer taking too long t
Check the fins on the fan impeller. They may be covered in lint or not spinning adequately.
Mar 05, 2017 | Frigidaire FGQ332ES Gas Dryer
Dryers Logo
35 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
