Question about Zebra Z4Mplus Label Printer
Barcode Problem Barcode does not print all the way, only 4 lines are visible.
Check the PRINT WIDTH in the configuration.
Posted on Sep 18, 2007
BROTHER MFC J435W BARCODE PRINTING PROBLEMS
Sounds like a problem with the printer. The software that came with the printer should have some tools that might help you, My old Epson printer came with a set of tools, one in particular tool (which may help you) was head aligment. This use to fix the issue of non straight lines being printed. Head cleaner was another tool i would use to have thin consistent lines printed. Check your printer install cd and add the extra software if all you have installed is the basic driver.
Dec 14, 2013 | Brother International Brother MFC-J435W...
Tip
How do I read barcodes from an Adobe PDF FILE?
<p>Reading a bar code in a portable document format (PDF) document is a simple procedure. Some newer phones come with smart barcode scanners, and you can scan the Internet to buy. A barcode is a series of lines of code that identifies a product. When you print the document with a single piece of technology, you can read a barcode in a PDF document. <br /> <p><br /> <p>1. Open the PDF document. Adobe Reader PDF reader is the most common. If you do not have Adobe, download the latest version of the company's website for free download (see Resources). <br /> <p><br /> <p>2. Select "File" drop-down box to the left of Adobe. Select "Print" and then "OK". <br /> <p><br /> <p>3. Set the bar code scanner. Jumping the gun and a horizontal red line is designed with the focus of the scanner. Move the line through the barcode printed on the document until the scanner beeps. Release the trigger and see the screen on the back of the scanner, which will give you the information encoded in bar code. <br /> <p><br /> <p>4. Download a barcode scanning application for your smart phone if you do not want a handheld scanner. Most bar code applications are free. Open the program and point the camera at the barcode in the PDF. Wait until the camera for a snapshot of the barcode will not make up the barcode in the light of the entire camera to take. The program will decode the barcode and display the results. <br />
on Jun 26, 2011 | Computers & Internet
Hello, I have a problem with Zebra Z4M Plus
Hi, if is the vertical line, its the print head that need to be replaced,
try to clean the print head and try this to confirm:
turn printer off, press PAUSE button and at the same time, power on, don't release the button, please wait until printer LCD screen come on, then release button. It will print the PAUSE test and after few 3-4 prints, u can turn off and on again otherwise printer not ready to print your labels until u restart it. (pause test stops after 10-15 labels). this pause print just show how the print head is and if come with vertical lines, u will need to replace. other idea is (if u can) turn the bar code different position or on vertical way at label format. Thanks.
Aug 04, 2013 | Zebra Office Equipment & Supplies
Hp m1005 scanner error 12
The Scanner has gotten out of its course, other words, this scruffy
To work around is simple, just loosen the 4 screws on top of the scanner, are well visible, it is necessary to open the printer, but only to cover the Scanner is not necesario completely extract the screws, but only a little solitary the scanner back in its correct line!
Hope I have helped
May 03, 2011 | Computers & Internet
We use 2 column lables and when we print the barcode on the second side will not scan. there is missing lines in the barcode.
possible, need printhead replacement. Try to.
Turn printer off,
press pouse button,
turn printer on, still pressing pouse button for 10 seconds, and then relese the button. the printer will print the pouse test with barcode, check if coming with wihte lines across, if yes, change printhead.
Mar 03, 2011 | Zebra Z4Mplus Label Printer
The printer is not feeding the label until the perferated line. it only feeds about an inch and then stops and then feeds another inch. on our other zebra once the feed button is pushed the printer feeds...
Simple yeah. Printer calibration is the problem.
see this video , http://vodpod.com/watch/3948392-how-to-calibrate-zebra-tlp-2844-printer
For over 4 years, Trridev Labels has provided Barcoding solutions and Barcoding equipment to a wide range of large and small companies in virtually every industry sector. Trridev Labels offers more than 10,000 brand name products and services such as Barcode Labels, Barcode Printers, Barcode Scanners, Thermal Transfer Ribbons (Wax, Wax Resin, Resin), ID Card Printers.
Contact Trridev Labelss Mfg Co – If you have requirement of Barcode Labels, Barcode Printers , Barcode Scanners, Self Adhesive Labels, Thermal Transfer Ribbons, Printer Heads, RFID Solutions, Barcoding Solutions. We provide you a complete solutions for barcode.
Call us at +91 – 96000 07995 / 98840 42305 To Get the Best Price Tagged with Best Quality.
Jul 02, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Ladder orientation barcode printing bad resolution needs correcting
Try slowing down the speed of the printer. Faster speeds degrade the quality of your print. Try printing your serial (ladder) barcodes at 2-4 inches per sec. It should improve the quality of your format.
Apr 13, 2009 | Zebra Z6M Plus Thermal Barcode Label...
Z4M is printing fine white lines in the barcode
As the label comes out of the printer...it sounds like your printing in picket fence mode (vertical bars). You most likely have 1 or more pixels out on the printhead...try cleaning first...if that fails... you will have to replace the printhead.
Apr 16, 2008 | Zebra Z4M Printer
Can't get barcodes to scan?
have you tried different darkness settings? it sounds like you only need to turn the darkness up a little.
Apr 02, 2007 | Zebra 110XiIIIPlus Label Printer
Zebra Z4Mplus Label Printer Logo
87 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Gateway information...
Marvin
Marvin
Joaquim Martins
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
