Question about Electrical Supplies
Kipor kDE67000T NO 240 OUTPUT
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Why do I not have any output?
Possible dirty contact or defective.
Jun 21, 2014 | Kipor 3000 Watt Generator
What is wrong with output?
Here is a PDF with troubleshooting tips and wiring diagrams: http://www.kiporpowersystems.com/pdf/service/IG3000~1.PDF
From Page 36 - If no AC power, first check for continuity between the terminals on the receptacle and the red and black wires going to the inverter module. See the wiring diagram. Check the contacts for discoloration or evidence of burning.
I have a kipor power with a fault code p-03 and it shuts off after a cople of secends . what could be the problem.i found in a forum that the posible cause could de the avr put i do not no were its located...
press and hold the function button turn on the ignition and hold until it ges into test mode should display something like ph 2 then start it up and test the output voltage and wether or not it produces power correctly. if it does test the output voltage with a multimeter to confirm the output is the same as displayed on the machine if not remove the control panel and adjust the trim pot on the rear of the display panel until it displays correctly,
if not it could be the carbon brushes in the altenator or the avr which is a black box bolted to the frame
Mar 09, 2010 | Kipor Electrical Supplies
I need a 5kW DC generator with -48v output.
I have 5kW generators that produce -48V DC. The problem is that unless your generator is designed to produce -48V DC it would be difficult to retrofit an existing AC voltage output with a DC output.
Nov 25, 2008 | Kipor Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
