Question about Numark TT1650 Turntable
Slow The turntable is turning very slowly and the music/voice is slow and distorted. Is there anything that I can check or adjust?
Can the belt be replaced or is there a different solution?
If it is slow on all speeds then replacing the belt might solve the problem. If it doesn't it could be grease that is bunging up the drive, or perhaps the motor needs oiling.
Mar 10, 2016 | Audio Players & Recorders
Turntable playing too slow
there is a (v.r) for speed in side look for it and turn it a little
Mar 24, 2014 | Technics SL-BD20D Turntable
Sounds low and slow
You can contact the Crosley website and they should sort out the problem you have, as the machine is under warranty.
Feb 23, 2014 | Crosley 0187SST Turntable
Distorted sound on pc women sound like men voices
Maybe your speakers are bad. How does it sound when you play a music cd or when you watch a music video on Youtube.com?
Mar 28, 2012 | Computers & Internet
I have a Sony PS-LX210, and need to adjust the speed. Going by the music it's played, it's just a bit slow on 33 RPM (I don't know about 45). I find no external adjustments, but there are some trim pots...
According to anything I can find online, like any decent turntable it has a manual pitch control. Unfortunately, I can't find a manual or even a good close-up picture.
This is the best one I've found.
http://www.neowin.net/forum/topic/652451-post-your-vintage-tech/
What's that rectangular slider-looking thing at the front right edge?
Feb 10, 2011 | Sony PS-LX250H Turntable
I have just bought a pre-owned Technics SL BD-22 turntable and the speed is variable - when I adjust the pitch adjustment wheel it seems to get worse. On listening to familiar music it seems to be running...
Have a look at the bottom of the turntable. This type of turntable often have speed adjusters. They might be covered by a sticky label or something. If you can't see that go inside by removing the bottom and look inside for them. There should be two, one for each speed.
Sep 21, 2010 | Technics SL-BD22 Turntable
Sony Belt Drive Turntable Platen speed
Check for grease on the platter or anywhere in the mechanism. Sometimes somebody has messed around with the speed preset, there might be two. You could try adjusting them. Sometimes they are found on the underside of the turntable, covered up, or they will be on the PC board of the deck.
Jan 08, 2010 | Sony PS-LX250H Turntable
This is a question for my daughter who lives in Japan. She has a Crosley turntable she bought from Urban Outfitters. The stylus arm has suddenly started skating over the record, ie won't play anything. ...
I have no experience of Crosley turntables, however, stylus arm skating across the record surface on any turntable is normally due to the counter balance weight being incorrectly adjusted. In order to track across a record properly, the stylus must press down on to the record very lightly. If there is too little pressure, skating is what tends to happen. Too much pressure can cause distortion of the sound and excessive wear of the record.
At the pivoting end of the stylus arm, there should be a counter balence weight. This is normally adjustable (but not always - depends on quality and features of the particular turntable), and is used to set the pressure the stylus applies to the record surface, measured in grammes. The manual that came with it should tell you how to adjust it, but for most turntables stylus pressure is between 1 to 3 grammes.
If you dont have the manual, have a good look at the pivoting end of the stylus arm to see if soemthing is obviously wrong, or if not whether there is something with numbers on it that can be turned or slid. This is likley to be the counter weight. Try adjusting it.
Within reason, the stylus weight isnt critical so a "trial and error" approach wont do any harm.
Nov 12, 2009 | Crosley CR249TA Turntable
Distorted voice on computer music
go compaq .com download latest sound driver for your model under help drivers area k
Oct 07, 2008 | Compaq Presario SR1050NX (DW257A) PC...
Sound Distortion
use sonic slide switch and make ground connection between your 640p and turntable.-check cables and test with another good cables.-shut down any light dimmer around you and test.
Jun 29, 2008 | Cambridge Audio Azur 640P Amplifier
Numark TT1650 Turntable Logo
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
