Laptop red screen
When i start my laptop red display showing
    Sergeant:
  • 396 Answers
The problem may very well be the connector that hooks the motherboard and display together, has been shaken loose, and needs to be re-inserted.
Worse case: It could also be that the graphics chip or display is failing. MOST graphics chips on laptop motherboards are soldered to the board and cannot be replaced.
Posted on Jul 23, 2013
Dell laptop display
This can be one of two things. The first is unlikely, the display cable has become loose. The second is more possible, the screen has gone bad and needs to be replaced.
Aug 17, 2015 | Dell Computers & Internet
Toshiba Satelite 105 4134 Major Resolution Problems
Sounds like your screen is going bad. It's either the screen or the video card inside of the computer, but most likely it's the lcd screen. Try connecting an external monitor to the laptop. You can Borrow a monitor from a neighbor, friend, relative or co-worker to connect to the laptop.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the external monitor displays correctly that proves your video card is ok and your lcd screen is bad. If the external monitor displays the same as your lcd screen then your video card has a problem. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 23, 2012 | Computers & Internet
Toshiba satelite pro red spot on screen
Sounds like your screen is going bad or your video card is bad. Try plugging an external monitor to the laptop to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and plug it into the laptop. if the borrowed monitor displays without the red spot then your original monitor is bad. If the borrowed monitor shows the red spot then your video card inside the computer is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 12, 2012 | Computers & Internet
My samaung notebook screen does not show coler it seems red points on home screen
If the screen is mainly red, you need to replace the LCD display panel. First! hook a spare monitor to the video output usually on the back, if picture okay! the above mentioned needs to be changed, but if both show the same symptom it is the video graphics card that is the problem normally built into the motherboard.
Apr 23, 2012 | Computers & Internet
Why are there green and red lines on my mac lcd
Them monitor is starting to fail. You will need to purchase a new one unless you are still under warranty.
Nov 16, 2009 | Compaq Presario M2000 Notebook
Sony pcg-5a1l display problem
what do you mean display problem ? the red shows as pink ? the screen is black ? the screen is dimmed ? the screen produses smoke ? images are distorted ? screen is crashed ? - i can guess 100 things that mean "display problem" :)
if its not a software issue then it should be vga or tft... and are very expensive to fix... see for a new laptop...
Sep 03, 2009 | Sony Computers & Internet
My Hp pavlion dv 2500 laptops display screen is not showing anything but internal os starts ...........automatically whenever i starts laptop..
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 31, 2009 | HP Computers & Internet
HP Pavilion dv6000 Black Screen!
have you tried an external screen? did the same happen there
Mar 12, 2009 | HP Pavilion dv6000z Notebook
Dell Vostro 1710 display problem
Hello My Dell Vostro Laptop Display Not Working Correctly it showing Dim but in other desktop when i connect to the Laptop Of Mine it showing Correctly With No Dim Problems? How can I fix the Problem?
Nov 19, 2008 | Dell Vostro 1500 Notebook
Toshiba satellite m35x s149 displays red pixels for black pixels
if you have a warranty - have the manufacturer replace the lcd display unit.
Sep 26, 2008 | Toshiba Satellite 2250XCDS Notebook
Computers & Internet Logo
David Payne
David Payne
