Question about Gucci Watches
Gucci keeps beeping
Gucci watch keeps beeping code ref 1142
SOURCE: How do I open my gucci watch to change batteries?
Get a #0 1.6mm precision Phillps screwdriver (these are brittle) or similarly strong, thin piece of steel.
Hold the watch upside-down across your index finger while gripping the straps tightly between your index finger and thumb on one side, and index finger and middle finger on the other (ie. squeeze the strap around your index finger).
On the underside of the watch, stick the tip of the screwdriver under a square slot where the watchband is connected at an angle perpendicular to the strap. Firmly pry upwards on the cover on one side, then the other, until the cover pops off.
The battery is a Renata 379.
To put the cover back on, align the square slots precisely with the ends of the straps (keep these out straight), then firmly push the cover straight down until it "snaps" shut.
Posted on Jul 25, 2009
  • 65 Answers
SOURCE: How to Open a Gucci watch
Most watches are either screwed on and typically have a series of small notches around the circumference of the case back. A special tool is generally called for. Otherwise they are "snap back" . These are simply pressed on. To remove you can carefully use a regular knife in the absence of a "case knife". There is usually a small gap/groove/notch area to insert the balde and lift the back off.
  • 93 Answers
SOURCE: My crown fell off the stem of my Gucci watch. How
If you still have the crown you may be able to put it back on yourself. However for a secure repair you would need a watchmaker to repair this.
To try yourself get some RED locktite (available at any Ace hardware store or automotive store) Put a small amount on the threads of the crown. Then screw the crown onto the stem as much as possible.
Let it sit for about 10 minutes so the locktite can cure. Then you can try using it to set the time or whatever.
If this does not work you will need a watchmaker to repair this.
Prices to fix this would vary.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Posted on Nov 03, 2009
mcdevito75
  • 1970 Answers
SOURCE: In a ladies gucci watch 3900l How do you put in a
mcdevito75 here, Best Bet on your Gucci watch battery, look for a small watch repair shop in your area to replace the battery.
Posted on Jul 09, 2010
  • 906 Answers
SOURCE: Gucci watch looses 10 mins a day after battery change
Please refer this matter to expert. Kindly run through below website for assistance in finding the nearest outlet/dealers in your country.
Gucci
Posted on Jul 27, 2010
My Gucci serial number is 10860032 is it fake or original
Bobo, contact Gucci. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gucci Official Site United Kingdom
Top 10 Tips to Identify Fake Gucci Watches
The difference between real gucci and fake gucci
May 02, 2016 | Gucci Watches
New Gucci watch is not running, will taking off the plastic film with the red strip on the back make a difference.
That decal/sticker is usually only an indicator of a un-worn watch.
The only thing that will turn the battery on is pushing in the STEM.
If it does not run then... your battery SHELF LIFE has been
exceeded... Time to get a new battery
https://www.gucci.com/us/en/st/faq
Gucci offers a repair service for Gucci products purchased from Gucci.com, ... Watch Repairs* East coast: GTS 50 Hartz Way Secaucus, NJ 07094 tel 1.866.692.8244
Gucci Gucci
Dec 14, 2015 | Gucci Watches
Where can I find extra links for a Gucci 3600M mens watch?
At Gucci where else ! Look for Gucci on line , or Top End Watch Retailer
Mar 16, 2015 | Gucci Watches
What's the proper battery for my Gucci 6400L?
Ensure the watch battery is dead. A Gucci watch is not exactly a cheap trinket, thus the battery should have a fairly long lifespan before requiring a replacement. Once you see the hands of time stop on the face of your luxury item, you can be sure it is time to purhase a new battery. The typical cost for a new battery starts at $50. There are three categories for a Gucci watch: Automatic watches, quartz watches, and bracelet watches. Depending on the type, you will need a battery that suits one of these classifications. Batteries for Gucci watches can usually be obtained on any discount/surplus website (e.g. eBay, batteryright.com, or the actual Gucci store).
Read more : http://www.ehow.com/how_4966607_change-gucci-watch-battery.html
Jul 03, 2014 | Watches
Gucci watch serial number check
Hello, Gucci will be able to verify the serial number on their customer service line: 1 (877) 482-2430
May 12, 2014 | Gucci Watches
How can i tell a fake from authentic?
mcdevito75 here, Best Bet is to look for a small watch repair shop in your area, they can authenticate your Gucci watch for you. If you can, remove the back cover of your Gucci and record any and all numbers and other info off the watches movement itself then check online at Gucci.com. If your not familiar with watches, specially Gucci an expensive watch let a small watch repair shop remove the back cover and give you all info needed to authenticate the watch.
Oct 23, 2010 | Gucci 03665 Wrist Watch for Women
Gucci watch 19 years old had battery changed and glass now full of condensation when I wear - clears up when not worn?
Thank you for contacting FixYa.
After a battery is replaced, some watches require new gaskets, or O rings, etc to keep the watch water resistant. Prob the case with your watch. I would check with a qualified local watch repair or try Gucci at following link:
http://www.gucci.com/us/assistance/assistance
Best regards. Jewel
Oct 04, 2010 | Watches
Watch didn't come with instructions and/or care information.
The Gucci web site doesn't have any instruction download feature, so I suggest that you find your nearest store form their web site "gucci.com" and contact them for instructions.
Feb 20, 2010 | Gucci 112 YA112510 Watch for Women
Watch band broke on Paolo Gucci Womens watch PG873WS
I have here the official website of Gucci for your ready reference. You can run through below link to find assistance. Kindly change the country from where you are.
Gucci
Sep 07, 2007 | Gucci PG873WS Wrist Watch
Watches Logo
57 people viewed this question
Top Gucci Watches Experts
Lawrence Oravetz
John mullen
Are you a Gucci Watch Expert? Answer questions, earn points and help others
