Question about Panasonic CS-PS24MKH Econavi Inverter Standard Air Conditioner FOR 220 VOLTS
Timer light The timer won't switch off and AC keeps shutting itself off.
3 Suggested Answers
SOURCE: iThe timer light flashes orange and the unit
Try to reset the machine by turning it off and plugging it off from the main. Press and hold the power button (15-20sec) to drain the flea power. Wait for 20-30 minutes before plugging it back to the main and turn it on.
Post your observances here.
Posted on Aug 12, 2011
SOURCE: My Panasonic airconditioners keep stopping after
What is happening with th ac and is it a split or ducted
Posted on Feb 06, 2012
Won't power on
It might be that the water flow switch is faulty, this will allow the unit to light up but will not start
Jul 12, 2013 | Heating & Cooling
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
My lights on my 1996 caravan won't shut off until the timer shuts them off and they turn on when any door is opened
You are talking about interior lights, right ?
As long as the on-time is under a minute or two, its normal.
The lights are supposed to go off as soon as you start the van tho.
Jul 02, 2012 | 1996 Dodge Caravan
I have a intermatic T104m pool timer. The clock works but it doesn't shut off. I have to flip the breaker to shut it down. The manual override switch flips back and forth but nothing happens. ...
If you are flipping it off manually and it still won't shut off then the contacts are burnt together internally.
This means that you need to change this timer out....
If you switch it with the same timer you will not need to change the whole box... the old board will snap out and the new board will just snap in the old box, making the change out much more simple.
heatman101
Aug 15, 2011 | Intermatic T104M 208-277Volt 40-amp Timer...
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
http://www.smarthome.com/25077/Intermatic-EJ351C-24-Hour-Mechanical-In-Wall-Timer/p.aspx
http://www.amazon.com/Intermatic-EJ351C-Programmable-Mechanical-Security/dp/B000Q9YUGU
Aug 08, 2011 | Intermatic Hardware & Accessories
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
Panasonic CS-PS24MKH Econavi Inverter Standard Air Conditioner FOR 220 VOLTS Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
