Question about Opticon Office Equipment & Supplies
Opticon scanner wont turn on - Opticon Office Equipment & Supplies
Error - 8 on Opticon PHL 2700
It happened to me once. I basically reboot the opticon. and upload the data to the opticon again. and problem solved.
Apr 16, 2013 | Opticon PHL 2700
Tab key configuration
manual can be found at http://www.opticonusa.com/pdf/Manuals/Universal_Menu_Book.pdf on page 104 (U97) scan the "set" bar code followed by the "Tab" bar code and then on the "End" barcode
Mar 16, 2013 | Opticon OPR 3201 Barcode Scanner
Is there a way to check the configuration of a OPTICON OPI 2201?
usually there are no settings as most computers see the barcode and crdit card scanners as keyboard/input devices. unless the manufacture has additional software and drivers the device is simply an input capture device.
Mar 23, 2011 | Opticon Computers & Internet
Windows 7 cannot detecct my OPN-2001
It seems that this only has drivers for Windows XP, but you can try installing the XP drivers on windows 7.
http://old.opticon.com/uploads/Software/USB%20Drivers%20Installer.exe
Here is the link to download the drivers, make sure the scanner is not plugged in until after the drivers are installed. This may not work, but i have had to do this with other hardware and sometimes it does work.
Feb 28, 2011 | Opticon OPN 2001 Mobile Data Collector...
Download software?
You can find free software (and source in C#.net) for the Symbol CS1504 (and Opticon OPN2001/2002) at www.barcodedevice.net
Nov 18, 2010 | Symbol CS1504 Handheld Barcode Scanner
How to download service manual for lge cdma model
This is the Opticon website:-
http://www.opticonusa.com/solutions/tech-support
The only manual they have is the Universal menu manual.
If you can't find the manual you need here, I suggest you contact their tech support guys and ask them to point you in the right direction.
Apr 13, 2010 | Opticon LGE1105RHHS-000 Handheld
Opticon OPR-3201-USB computer does not recognize scanner.
get your manual and scan in the appropriate "host" option. You will have to scan in the "USB host" barcode. There may be more than one. Your scanner should be set to the HID usb Keyboard option. Or contact the Opticon Help Desk. You can download the manual at http://office.manualsonline.com/manuals/mfg/opticon/opticon_scanner_product_list.html
Oct 30, 2009 | Opticon LGE1105RHHS-000 Handheld
I cannot get my opticon barcode reader to work with my wirless keyboard. I have a Dell computer, and a Microsoft wireless keyboard I have the hand-held CCD Wedge Interface (25-wedge-06 Opticon Bar code...
Hi!
Keyboard Wedge Barcode Scanners are sometimes tricky because they will not operate if the keyboard is physically attached to the Scanners' "Y" cable. A possible solution would be to attach an additional keyboard to the "Y" cable and simply set it aside un-used. (This would allow you to continue to use the Wireless Keyboard; which I assume is USB). I may also be able to program the scanner to operate in a Laptop Mode which would allow you to operate successfully as-is. I would need your exact model number to investigate if this is possible.
Hope this helps!
-Dave
Dave Krause
Founder, Bluesky America's GetOpen.com
720.771.5194 Direct 888.7.GETOPEN Toll-Free
Apr 02, 2009 | Computers & Internet
Won't read fonts
Please try to reset your scanner configuration, using some utilities from it's manual book (usually available at it's case/box), restore it (usually by scanning it) to original factory configuration or scan a label that would enable all symbologies.
Aug 03, 2007 | Opticon LGE1105RHHS-000 Handheld
Top Opticon Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Opticon Office Equipment and Supply Expert? Answer questions, earn points and help others
